Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
new to truggys looking for some help?
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 02-10-2011, 09:46 PM
mx51
Default new to truggys looking for some help?
I just picked up my first truggy. I have been running the sc class with an sc8 so i am familiar with those..Now that i have a truggy the sepup will be different from my sc8.Where do i start what should i set the diffs at i have them at 5k/5k/5k right now? And then the shocks i have them at 40 and 40 now any info what be apprciated thanks guys.. o and the truggy is a ofna jammin x1 crt
Old 02-11-2011, 07:06 AM
SMOKEFAN
Default RE: new to truggys looking for some help?
I personally would go 5k,5k, 10krear. I like a little heavier oil in the rear
40wt likely okay but you will want to play with pistons and springs to get a setup you like. Best thing you can do is take it to the track and see what your starting with
Old 02-11-2011, 07:59 AM
pigpen1
it should be 7 10 2 to start its what the pros run
Old 02-11-2011, 08:07 AM
guntek18
40wt. silicone is really too heavy if its a bumpy track, try 35wt. or just a littlelighter to soak up the moguls and land softly on the big jumps.40wt. will rebound too hard. usually the pistons installed from the factory are fine, its just the shockoil that needs changing.
7k/7k/3k or 7k/10k/3k/ ..two good starting set-ups.
if you go too heavy in the front or rear, you will not get good "diff" action in the turns meaning, the inboard wheels will not break-loose from the outboard wheels and you will not turn tight as you would like (especially on loose/ low bite tracks).
Old 02-11-2011, 10:02 AM
mx51
hey thanks alot guys that helps a bunch i will try these settings and go from there
Old 02-11-2011, 10:24 AM
jmaxey51
when i had a Jammin X1 truggy i ran 7k-10k-3k always.... if running the 16mm shocks, 45WT oil all the way around, blue springs worked great... if 13mm, if i remember right, ran the dark blue springs with 50-55WT...
Old 02-14-2011, 04:28 PM
revo_sbs
My Feedback: (23)
Good question. I had this a while ago as I am somewhat new to the truggy scene. I took a look at the Truggy Setup thread and compiled some data. 7k/10k/3k was the most popular diff fluid combo. As for shocks 40wt was most popular up front. There was a tie for rear shock oil between 40 and 50. I used these as a starting point. Its all about the track, and how you want her to handle.
Old 02-14-2011, 10:20 PM
mx51
well maybe just meet in the middle with some 45...LOL thanks for the info man thats really good to know!!!
