best Li-Poly charger?
NM
Hey guys thinking of moving over to a ProTek Li-Poly receiver battery pack i know i will need a voltage regulator. What would be the best charger for this battery under 200 dollars? Thanks
RE: best Li-Poly charger?
I use this one. The ability to charge two packs up to 6S at up to 10A simultaneously is awesome for me, since my two main cars use dual batteries.
http://www.amainhobbies.com/product_...S-10A-200W-x-2
If you don't need the duo version, the single version is quite a bit cheaper...
http://www.amainhobbies.com/product_...er-6S-10A-200W
And this is a pretty good combo deal...strong power supply, but you can get power supplies cheaper.
http://www.amainhobbies.com/product_...0-Power-Supply
I use this power supply, I can charge 2 6S packs simultaneously at 6A using the duo with this. It's a little underpowered, but good enough.
http://www.amainhobbies.com/product_...r-Supply-Black
