Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
need help with my thunder tiger st-1
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 01-04-2012, 05:19 PM
jwgillespie
Default need help with my thunder tiger st-1
help
i have just recently got my thunder tiger st-1 and finding it quite hard to start
But i have found the idle speed ( speed at which it can just sit at)
but when i try to go to full throttle it cuts out and stops
if you know what is wrong can you please help me
my car is also steering the opposite way in which it is ment to be????????
Old 01-05-2012, 09:13 AM
kawpow321
Default RE: need help with my thunder tiger st-1
for the steering there is a little switch somewere on your remote that reverses the fuction in your case it would be channel 1 for steering that you would wana reverse...and as far as your engine if i were you i would find your factory needle settings and put your carb back to that and run atleast 4 full tanks through it turning your high speed (the screw next to your fuel outlet) in clockwise 1/8 turn after each tank theres a nice video on you tube called tuning your nitro made by squirell sounds like your new to this so i would watch the video and take some notes and if your engine becomes hard to pull start take your plug out turn the kit upside down and pull the starter a couple times to blow out any excess fuel good luck when you get down its nothing i was new at this at one time and it does become overwelming but you ll get it
Old 01-05-2012, 01:29 PM
jwgillespie
thanks alot
i will look into that you tube video
Old 03-10-2012, 08:52 PM
szewang2805
Banned
thanks a lot too [link=http://www.hobbyhot.com/HOBBYWING-XERUN-Series/][/link]
