RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
a little help here?
Old 02-05-2013, 01:16 PM
Rampede
Default a little help here?
I just bought an exceed madstorm and it needs clutch shoes springs and whatever is supposed to hold it onto the shaft. Can't f ok nd parts anywhere that are in stock. Any help would be appreciated
Old 02-06-2013, 09:37 AM
Anthoop
Anthoop's Avatar
Default RE: a little help here?
It is a 3 shoe clutch? 3 shoe/spring sets from other cars will work.
Not sure what you mean by "and whatever is supposed to hold it onto the shaft", nothing holds the clutch shoes onto the flywheel pins. There should be a long nut with a reccess to hold the flywheel on and a allen headed bolt to hold the clutchbell on.
Old 02-06-2013, 11:35 AM
nitroexpress
nitroexpress's Avatar
http://www.nitrorcx.com/sparepart52c63.html
Old 02-07-2013, 01:06 PM
Rampede
Nitroexpress, I've looked there it's out of stock.
Old 02-07-2013, 01:14 PM
Rampede
Anthoop thank you. I was looking through clutch kit online an I'm seeming a whole bunch of washers, a brass cone lookin thing, and some 2 step washer things. I got the truck with the motor out and clutch off the motor and I have the flywheel nut have THe cone brass thing but I also have a nut the same color as the flywheel nut but one end is rounded. Yes it is a 3 shoe clutch and I found this clutch kit but if I if it will work on my sh.28 I wish I had a blown up diagram of clutch assembly
Old 02-07-2013, 01:36 PM
Rampede
So theoretically the clutch shoes and springs for savage will work?
Old 02-07-2013, 02:02 PM
Anthoop
Anthoop's Avatar
ORIGINAL: Rampede
Yes. If it has a 3 shoe clutch.
In your previous post you say you have a rounded nut? Can you upload pictures...it will be easier.
Old 02-07-2013, 03:30 PM
Rampede
I wish I could but I'm using the wife's kindle fire. and I mean the nut kid of reminds me of a prop nut but slightly different. As for the brass cone with one side cut from top to bottom do you know what that is? All I know is the clutch bell uses 2 bearings and that's literally all I know. Idk If I I'm asking too much but if you could explain the assembly of the clutch then I could picture it and see if I have everything else besides the shoes and springs
Old 02-07-2013, 07:26 PM
nitroexpress
Old 02-07-2013, 07:33 PM
nitroexpress
[youtube]http://www.youtube.com/watch?v=Po9r2a6X3r4&feature=player_detailpage[/youtube]
Old 02-08-2013, 02:37 AM
Rampede
What was that picture of it showed up as a puzzle piece
Old 02-08-2013, 04:35 AM
Anthoop
Anthoop's Avatar
ORIGINAL: Rampede
In the picture below the odd shaped nut is the flywheel nut and the cone with one side cut fits onto the crankshaft before the flywheel (in the previous video he refers to it as the collet).
Old 02-08-2013, 06:31 PM
Rampede
Thank you, just picked up an RL20 clutch kit with new flywheel clutch bell shoes and springs I had to modify the flywheel but it should work but right now I'm really bumming because I bought everything I needed except the four Dang nuts and bolts to bolt the engine down I got it all together and said [email protected]$&
Old 02-09-2013, 11:21 AM
Rampede
Thanks again Anthoop, it's running and driving and it actually surprised me how quick it is.
Old 02-09-2013, 11:31 AM
Anthoop
Anthoop's Avatar
No problem. Glad you are having fun....give yourself a pat on the back.
Old 03-05-2013, 04:26 PM
nitroexpress
ORIGINAL: Rampede
It was a video. You might have to update your computors FlashPlayer to see it.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
