RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Kyosho motor mounting
Old 07-01-2015, 06:30 PM
Walcon
Default Kyosho motor mounting
Hey all I have a Kyosho inferno ST new race spec. I just purchased a LRP .28 3spec with a pull start and I can not get the motor mounted properly. It looks like the motor mounts rub against the crank case where the pull starter is. The pull start is square as opposed to the rounded stock pull starter it looks like I might be able to grind down the stock motor mounts to make some room for the motor. Is this the best option or should I look for another solution?
Old 07-04-2015, 08:11 AM
Anthoop
Anthoop's Avatar
Engine you mean.....a motor uses electric!
The LRP.28 has a large backplate/pullstart...on cars that I have then it can be usual to modify the mounts to make it fit.
Pictures will help as I do not have the same model as you.
Copyright © 2022 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
