Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
Need help on the brushless conversion of XTM MMT
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 06-15-2016, 06:06 AM
kenlhmaxx
Default Need help on the brushless conversion of XTM MMT
hi guys
Plan to convert my XTM MMT to a brushless powered , just wonder are there any compatible center differential mount and center differential from other brands that i can swap and install into the mmt without modifications ?
please advise
Old 06-15-2016, 11:16 PM
Maj_Overdrive
Maj_Overdrive's Avatar
There are no bolt in brushless motor/center diff mounts for that vehicle and I doubt any other center diff would fit without modifications either. But you do not wa t to swap in a different so enter diff anyway. The spur gears are larger in diameter than most truggies due to the ratio of the front and rear diffs. The front and rear are buggy ratio (3.31:1) and combined with monster truck size tires requires a large spur gear to get the required reduction ratio. That's why truggies use 4.10:1 for their front and rear diffs so they can run a normal size spur gear.
You're best bet is making a motor mount that attaches to the chassis. You could even use the original engine mounting holes in the chassis to bolt it down. Then get a battery try's, mount it, install electronics and let err rip.
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
