Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
 some help on engine choices for crt pro kit >
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 03-08-2006, 05:29 PM
mayhem272's Avatar
Default some help on engine choices for crt pro kit
yes i no theres a thread bout this already but
this is wat id get if i were to order it online
N528XR NovaRossi .28 8-port $349.95 $349.95
PRO321300 Crowd Pleazer 2.0 Body - Jammin X1-CRT $27.20 $27.20
ZMT034 MSR Truggy $599.95 $599.95
10208 12 volt battery for starter boxes. $19.95 $19.95
10212 6 volt NiMh receiver pack, Hump 1400 $19.95 $39.90
10905 Blue Alum Car Stand $27.96 $27.96
10165 Aluminum Fuel Filter Fine Mesh $5.95 $5.95
10217 Glow Starter w/1700 mAh & Chgr $16.96 $33.92
B0317 10,000 WT DIFF OIL MUGEN $6.37 $6.37
B0334 2,000 WT DIFF OIL MUGEN $5.52 $5.52
B0322 5,000 WT DIFF OIL MUGEN $5.52 $5.52
10242 FOAM AIR-FILTER OIL, RED $5.06 $5.06
B0315 35 WT SHOCK OIL MUGEN $4.67 $9.34
B0316 40 WT SHOCK OIL MUGEN $4.67 $9.34
B0332 45 WT SHOCK OIL MUGEN $4.67 $9.34
SPM1200 DSM 3 Channel Surface Receiver $79.95 $79.95
AIR94358 Airtronics Hi-Torque 200 oz $105.95 $105.95
HS645MG Hitec Hi-Torque Metal Gear $39.95 $39.95
10253 1/8 Off Road Starter Box w/Power Panel $89.95 $89.95
10224 Charger for 12V battery. $11.95 $11.95
NOV52114 086 Polished, 1/8 Off-Road One-Piece Pipe $119.95 $119.95
10068 .21 Seals, Round Port Exhaust, 2 Pcs $5.95 $5.95
Total: $1608.92
from nitro house
and this from amainhobbies.com
1 x Jammin crt kit pro
1 x Pacer After Run Oil (1oz)
1 x Spektrum SR3000 DSM 3CH Receiver: Surface
1 x Hitec HS-625MG High Speed Metal Gear Servo S/JR/Z
1 x Team Orion 1400MAh 1/8 Off Road Hump Receiver Pack
10 x A Main 5x10x4mm rubber sealed "Speed" 1/8 clutch bearings
1 x AMBrc Personal Direct Powered Transponder
1 x Fluidz RENEW-IT Parts Treatment Spray (UPS Ground Shipping Only!)
1 x Fluidz FILTER-CLEAN Foam Air Filter Cleaner (UPS Ground Shipping Only!)
1 x Fluidz CLEAN-IT All Purpose Cleaner Spray (UPS Ground Shipping Only!)
1 x Kyosho Silicone Diff Oil 10,000wt (40 CC)
1 x GS Racing Pure Silicone Diff Oil 5000cps (2oz)
1 x Kyosho Silicone Diff Oil 2,000wt (40 CC)
1 x Associated Silicone Shock Oil 40wt 2oz
1 x Associated Silicone Shock Oil 35wt 2oz
1 x Associated Silicone Shock Oil 50wt 2oz
1 x Dynamite Piston Lock Tool
1 x OFNA Blue Knife Edge Reamer
1 x Kyosho Fuel Tubing (1 meter)
1 x OFNA 1/10 & 1/8 Stainless Steel Starter Box
2 x Power Racing 6 cell 7.2V 3300mAh NiMH Sport Battery Pack
1 x OFNA 17mm Half Offset (28mm) Monster Truck Yellow Dish Wheels (4) (X1-CRT)
1 x RB Concept S7II 7-Port Off-Road Competition Buggy Engine (Standard Plug)
5 x RB Concept Medium Glowplug #6 (1)
1 x Airtronics 94360 High Speed Servo with Heatsink
$1,480
now anything you recomend? are the servos fine? its in my price range
now the engine brands id choose from are os vspec (no jp modss tho!) rb (ws11 or tm928) or novarossi (528 series prefer xr) and they can be either 21 or 28 sized and not over $350
thanks
Old 03-09-2006, 09:46 AM
Default RE: some help on engine choices for crt pro kit
several points:
1. if you are planning to use the hitec for steering, FORGET IT! for as long as i have been racing, off-road application will best benefit something comparable to the airtronics 94359z!
2. as far as motor, it depends on the track. i personally use on my crt a Maxy modified P5 for short, technical tracks. for fast tracks, i use a 421B or i am trying to get the new PLUS35 offroad. the 528 has plenty of power, but not enough RPM's. we get better performance out of the .21's than anything else!
3. my opinion, don't waste your money on cleaners. if you have access, use Simple Green. it works excellent, it doesn't make your plastic opaque, and it is biodegradable
these are just my recommendations that have worked for myself as well as many of the racers where i run. everybody has there personal preferences and brands they like to use. i think that if you spec out what i listed and can obtain it through other brands that you like to use, you will be very satisfied with the end result and see yourself at the podium!!
Old 03-09-2006, 10:22 AM
I also think the Hitec 5925 is not strong enough to go on the steering, not to mention the 565. Personally, I use a 5925 for gas/brake and a Thunder Tiger ds1013 servo (who knows who distributes these in the US - see Ebay Germany auction # 7396945223) for the steering - strongest and fastest of all, beat my Hitec 5945. If you want a Hitec for the steering, take the 5945, but the Thunder Tiger ds1013 is faster and stronger.
I would also buy more different diff fluids to experiment with.
Old 03-09-2006, 06:25 PM
Have you thought about picking up a Z brace for the chassis ? and maybe a cnc one piece motor mount?
Old 03-09-2006, 06:38 PM
mayhem272's Avatar
yea thts what i wanted to know
i appreciate it all guys
im gonna maybe pick up the kit and order the motor and servos from the lhs (dont stock them due to robbery and tht stuff, its hard to explain) this weekend
i might get a .21 becuz of ur guys info
"not enough rpms" and the 21's are a tad cheaper
Old 03-09-2006, 07:25 PM
V-Spec
Old 03-09-2006, 10:54 PM
I feel I need to correct a common misconception of the Novarossi 528 and RB928. These engines rev like their .21 brothers, peak rpm is about the same and the way in which they rev isn't by any means lazy, they rip from the start all the way to their respective peaks. It's the thing that got everyone talking about it when it was released. The 528 in particular is about the only engine that you can believe the hipe about. I've found the 928 a little more drivable and easier on the fuel.
Ultimately which engine you get needs to be dictated by the depth of your pockets, skill level, types of track you race at and in the case of these two, IMO, your tuning experience, cause if your skilz aren't together you'll likely to have a nightmare with them. They are true race engines.
Old 03-10-2006, 12:29 PM
My Feedback: (7)
I just broke in a 528 and it is CRAZY powerful! This is the first car engine that I have owned, I fly planes too, and can not say enough positive things about it. I didn't have any trouble tuning it but my experience with aircraft engines might have influenced that. Mine is in a CRT and using the stock gearing, so the top end is not as high as it could be, but I can't imagine needing anymore! Maybe on a huge track, but the shear torque this mill puts out is addictive on many levels! I have not measured fuel times in a race yet but I get about nine minutes on a 150 mL tank so far. I agree that the Novarossi 528 lives up to its hype, and then some!
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
