Sportwerks Mayhem ST
#251
RE: Sportwerks Mayhem ST
Recieved KP Chassis kit today ! What an excellent bit of kit. So well made. If I was to get someone to make me one of these in the UK Id be looking at over $300 easy! Cheers Kevin . Have some building to do tonight and a big decision sunday ! Losi or Sportwerks ?????
#252
Big bond that body is sweet,Please post some pics of it when it's ready 2 go.
If anyone is interested I have a KP Chassied roller I wanna get rid of
,Kevin is a friend of mine and will tell you it's a nice truck
#253
already have have a look at www.createsometurmoil.co.uk under the mayhem section. Gave it a blast during warmup on saturday and then swapped to my New Losi 8T unfortunatly this gave me no choice.---- Losi it was for sunday. Good choice though Qualified 4th and finnished 4th well chuffed. Gona take the Mayhem out this saturday to local track and get a setup going.!! Even with 15mm extensions on it seams a little narrow. Does any one use offset wheels aswell to get some extra width ??
#254
hey guys, i have a problem startimg my myhem. I know the glow igniters might not be charged enough but the muffler get filled up with gas as the engine turns over. This has never happend before, could there be any other cause than a dead glow igniter?
#257
the fuel line is not pinched and it doesnt look like there is anything wrong with the fuel line, what else could it be?
#258
ok i checked the fuel klines and they dont seem to have any pinches or anything wrong but the truck still wont start, im starting to wounder if there is something wrong with the engine because there are no obvious signs that the truck shouldnt start
#260
i should have explained this better.pull your glow plug out and make sure your igniter is full charged.hold the glow plug with a pair of pliers and check the glow plug.it should get bright orange.
#261
I suggest to remove the pipe and make sure you have no fuel left in there.
The other is remove the Glow plug and copper spacer, Flip truck upside down and crank over the motor by hand.
You may find left over feul come out.
It sounds like you are flooding it somehow. If the motor is loaded up the only place it has left to go is in the exaust pipe.
As for the previous issue you had---take the center dogbones out and check to see how well the front and rear wheels turn freely. As for the breakes I used springs from pens to keep the pads dragging on the disk.
#262
ok thanks guys, the engine does flood but it doesnt make a difference if i empty out all of the fuel in the exaust pipe and engine. It doesnt feel like it has any compression anymore when im trying to start the engine, and the i did check the glo igniter and plugs they are in good condition.
#263
ok i think i found what the problem was with my mayhem, apparently there is no compression because the sleve and piston either got scratched or was not boken in properly. I did not find any noticable scratches so im guessing i did something wrong during the braking in of the engine. I heard that i did not break the engine in agressively enough but I followed the instructions that came with the engine. Has this ever happened to anyones else and do you think that is what i did wrong?
#271
FL
kind of hard to explain in writing but I will try you want as much smoke as possible with out sputtering fuel. you also can a solid sound from your engine so it is not leaning out. check out the racers at your local track this should give you a good feel.
#272
my mayhem has been running great for a while but then suddenly it just died, now every time i try and start it dieds shortly after, i've replaced the glow plug and that hasnt solved the problem, what do you guys think is wrong
#274
im still using the glow plug that came with the engine, its still working, i tried richening the high speed and low speed a few times but nothing helped
#275
BC, CANADA
Hey there, I was wondering if anybody out there knows what other bodies are available for the Mayhem ST (the stock one is kind of thin and prove to breakage ). I have the stock chassis. I've seen lots of different bodies that people have used with the extended chassis, would they also work with the regular one?
