Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
Offical Mugen MBX5T thread
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 06-24-2009, 12:07 AM
  #851
Krawlin
Krawlin's Avatar
Default RE: Offical Mugen MBX5T thread
Alright people here she is!
And yes I know my sealant job sucks. And it is Racers Edge sealant.
ID:	1223608   Click image for larger version
ID:	1223609   Click image for larger version
ID:	1223610   Click image for larger version
ID:	1223611   Click image for larger version
ID:	1223612   Click image for larger version
Old 10-20-2009, 01:50 PM
  #852
driller2948
Bump!!
Old 10-22-2009, 08:31 AM
  #853
Anomie
Anomie's Avatar
ORIGINAL: driller2948
Bump!!
Thread bumping is not allowed, but between the two of us, this will rise to the top
Old 10-22-2009, 08:38 AM
  #854
driller2948
I saved a link this time so I don't have to search for ever to find it
Old 12-06-2009, 04:37 AM
  #855
Skyline15
I've got question about mugen mbx5t diffs (front/rear) - Can I fit diffs from mbx6t? Anyone tried?
Old 05-25-2011, 11:45 PM
  #856
IROC-AR15
My Feedback: (10)
Is this thread still active? I'm about to get one and need some info on it!
Old 05-26-2011, 07:57 PM
  #857
INTEGRA
INTEGRA's Avatar
ORIGINAL: IROC-AR15
Last post before yours......... RE: Offical Mugen MBX5T thread - 12/6/2009 12:37 PM
Active, Not really. But what would you like to know ?
Old 05-27-2011, 08:50 AM
  #858
IROC-AR15
My Feedback: (10)
Okay...I'm getting a MBX5T Prospec and was wondering how should I set it up how durable it is and if there are any aluminum a arm upgrades for it!
Also what bodies fit it and the size of the wheels hexes....
I got a sweett deal on a roller for $150
Old 05-27-2011, 05:20 PM
  #859
INTEGRA
INTEGRA's Avatar
ORIGINAL: IROC-AR15
5T's are tough to say the least, There's For sure Multiple item's that will make the truck even more durable in the end.
For starter's You Do Not want aluminum arms, They are overly heavy and will transfer any force that would normally break a Stock arm Right to your pivot blocks which Stock are plastic and in desperate need of upgrading. http://kingheadz.com/ should have every part you could want for this machine.
Wheels and tires you are looking at anything 3.7 which are the taller truggy tire Vs the Older MT style Monster truck tires with fat side walls. 17mm for the hex and the 5T's run a Zero Offset wheel ( Hex mounts Flush to the face of the wheel )
Proline or AKA would be choices. here's a variety
Tires
http://www.amainhobbies.com/index.ph...er-Truck-Tires
Rims
http://www.amainhobbies.com/index.ph...r-Truck-Wheels
Old 05-28-2011, 01:22 PM
  #860
IROC-AR15
My Feedback: (10)
Okay cool it comes with some AKA on some Reflux wheels! Thanks its hopefully an upgraded from my TTR ST1 cause I Loved that truggy!
Old 06-03-2011, 01:49 AM
  #861
Sh1mmy
ORIGINAL: IROC-AR15
It doesn't really need anything to be durable, it's already stronger and more durable than you should ever need it to be.
They are very tough, resilient and take a fair bit of abuse.
Old 06-03-2011, 04:21 AM
  #862
IROC-AR15
My Feedback: (10)
ORIGINAL: Sh1mmy
ORIGINAL: IROC-AR15
Cool, the truck actually arrived yesterday and it looks damn good...Similar to my ST1 in design so I know its strong but built with precision machined parts!
Old 06-08-2011, 07:19 AM
  #863
IROC-AR15
My Feedback: (10)
Is it possible to mount a Losi 427 Spin Start engine on a MBX5T Prospec?
Old 06-08-2011, 09:38 AM
  #864
K_B
K_B's Avatar
You'll need taller RTR-style engine mounts to raise the engine up and clear the flange on the spin-start mechanism. You could also just shim the engine up using spacers on the Mugen engine mount but that won't be as strong.
Old 06-08-2011, 09:55 AM
  #865
IROC-AR15
My Feedback: (10)
ORIGINAL: K_B
What about doing what this guy done?
http://www.rccarbasher.com/mounting-...mbx5t-prospec/
Old 06-08-2011, 10:14 AM
  #866
supertib
supertib's Avatar
ORIGINAL: K_B
unfortunately your never going to find a RTR type engine mount for a Mugen as they do not exist....The demand for one would be slim and none as most people would consider going that route to be a downgrade........However with some dremel work and some creativity a pullstart engine can be fitted to the stock mount.....
Old 06-08-2011, 10:42 AM
  #867
K_B
K_B's Avatar
A two-piece mount won't work on the Mugen? I know Mugen doesn't do any sort of RTRs (one of the reasons I switched to Mugen) but I've done it on other brands with that exact motor. I was thinking you might be able to use Losi 8 RTR mounts, but because Losi uses that oddball clutchbell, the engine might sit too far back to use a standard clutchbell.
Personally, I find it rather sacriligious to put a pullstart/spin-start on a race-bred Mugen
Old 06-08-2011, 11:00 AM
  #868
IROC-AR15
My Feedback: (10)
ORIGINAL: K_B
Can't I just do this?
Old 06-08-2011, 11:26 AM
  #869
K_B
K_B's Avatar
I missed that earlier. That might work. You might have to remove more material and use more washers underneath. I think the spin-start flange is a little bigger than the pull-start types.
Old 06-08-2011, 11:57 AM
  #870
supertib
supertib's Avatar
ORIGINAL: K_B
the Losi mount may work, but you would have to machine the Mugen chassi to accept the Losi bolt pattern.... these engine mounts are not universal...
Old 12-19-2011, 08:42 AM
  #871
IROC-AR15
My Feedback: (10)
Thanks guys, I ended up just getting a backplate and starter box for my truggy. In fact I love the truggy so much I picked up a second brushless version to race the same platform in two classes next season.
The motor that I'm looking to get, actually two motors, is between the Team Orion Alpha .24 truggy engine or a Clockworks Argus A52 .21.
If I get the .24 I'm going to send it in for the Clocked treatment anyway.
I appreciate the help and suggestions guys, I'm hooked and feel this will definitely hold me down for a couple race seasons until a MBX7T comes out
Old 12-19-2011, 09:50 AM
  #872
driller2948
I know it's a little late but this what I did to bypass the starter box.
ID:	1702151   Click image for larger version
ID:	1702152   Click image for larger version
Old 01-06-2012, 12:52 PM
  #873
IROC-AR15
My Feedback: (10)
Here are my MBX5T's one brushless one nitro!
Brushless has Tekno Chassis and Tekin T8 1550kv setup
Nitro I am running Alpha A352 .23 Truggy, actually it still hasn't been opened still in plastic, what's in it now is a Losi 427 with a backplate of course.
I love these truggies hands down so durable and nimble!
Old 04-25-2012, 01:49 PM
  #874
mtz57
Hey alli just got a.mbx5t and i have everything but tires i see a huge slection but what tire size and rim id best for long life and still have some goood traction
Old 02-16-2015, 08:39 PM
  #875
Remote
Question for the MBX5T owners. I know this thread is OLD.... I hope somebody can help me out. Picked up a old MBX5T to more or less restore/ refurbish it. Can the chassis from a MSRX5-T conversion kit be used in place of the MBX5T chassis? I wasn't sure if the two were interchangeable.
Thanks.....
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
