Offical Mugen MBX5T thread
#857
MB, CANADA
RE: Offical Mugen MBX5T thread
ORIGINAL: IROC-AR15
Is this thread still active? I'm about to get one and need some info on it!
Last post before yours......... RE: Offical Mugen MBX5T thread - 12/6/2009 12:37 PM
Active, Not really. But what would you like to know ?
#858
My Feedback: (10)
MO
Okay...I'm getting a MBX5T Prospec and was wondering how should I set it up how durable it is and if there are any aluminum a arm upgrades for it!
Also what bodies fit it and the size of the wheels hexes....
I got a sweett deal on a roller for $150
#859
MB, CANADA
ORIGINAL: IROC-AR15
5T's are tough to say the least, There's For sure Multiple item's that will make the truck even more durable in the end.
For starter's You Do Not want aluminum arms, They are overly heavy and will transfer any force that would normally break a Stock arm Right to your pivot blocks which Stock are plastic and in desperate need of upgrading. http://kingheadz.com/ should have every part you could want for this machine.
Wheels and tires you are looking at anything 3.7 which are the taller truggy tire Vs the Older MT style Monster truck tires with fat side walls. 17mm for the hex and the 5T's run a Zero Offset wheel ( Hex mounts Flush to the face of the wheel )
Proline or AKA would be choices. here's a variety
Tires
http://www.amainhobbies.com/index.ph...er-Truck-Tires
Rims
http://www.amainhobbies.com/index.ph...r-Truck-Wheels
#861
ORIGINAL: IROC-AR15
They are very tough, resilient and take a fair bit of abuse.
#862
My Feedback: (10)
MO
ORIGINAL: Sh1mmy
It doesn't really need anything to be durable, it's already stronger and more durable than you should ever need it to be.
ORIGINAL: IROC-AR15
Cool, the truck actually arrived yesterday and it looks damn good...Similar to my ST1 in design so I know its strong but built with precision machined parts!
#864
You'll need taller RTR-style engine mounts to raise the engine up and clear the flange on the spin-start mechanism. You could also just shim the engine up using spacers on the Mugen engine mount but that won't be as strong.
#865
My Feedback: (10)
MO
ORIGINAL: K_B
http://www.rccarbasher.com/mounting-...mbx5t-prospec/
#866
ORIGINAL: K_B
unfortunately your never going to find a RTR type engine mount for a Mugen as they do not exist....The demand for one would be slim and none as most people would consider going that route to be a downgrade........However with some dremel work and some creativity a pullstart engine can be fitted to the stock mount.....
#867
A two-piece mount won't work on the Mugen? I know Mugen doesn't do any sort of RTRs (one of the reasons I switched to Mugen) but I've done it on other brands with that exact motor. I was thinking you might be able to use Losi 8 RTR mounts, but because Losi uses that oddball clutchbell, the engine might sit too far back to use a standard clutchbell.
Personally, I find it rather sacriligious to put a pullstart/spin-start on a race-bred Mugen
#868
My Feedback: (10)
MO
ORIGINAL: K_B
Can't I just do this?
#869
I missed that earlier. That might work. You might have to remove more material and use more washers underneath. I think the spin-start flange is a little bigger than the pull-start types.
#870
ORIGINAL: K_B
the Losi mount may work, but you would have to machine the Mugen chassi to accept the Losi bolt pattern.... these engine mounts are not universal...
#871
My Feedback: (10)
MO
Thanks guys, I ended up just getting a backplate and starter box for my truggy. In fact I love the truggy so much I picked up a second brushless version to race the same platform in two classes next season.
The motor that I'm looking to get, actually two motors, is between the Team Orion Alpha .24 truggy engine or a Clockworks Argus A52 .21.
If I get the .24 I'm going to send it in for the Clocked treatment anyway.
I appreciate the help and suggestions guys, I'm hooked and feel this will definitely hold me down for a couple race seasons until a MBX7T comes out
#873
My Feedback: (10)
MO
Here are my MBX5T's one brushless one nitro!
Brushless has Tekno Chassis and Tekin T8 1550kv setup
Nitro I am running Alpha A352 .23 Truggy, actually it still hasn't been opened still in plastic, what's in it now is a Losi 427 with a backplate of course.
I love these truggies hands down so durable and nimble!
#874
Hey alli just got a.mbx5t and i have everything but tires i see a huge slection but what tire size and rim id best for long life and still have some goood traction
#875
FL
Question for the MBX5T owners. I know this thread is OLD.... I hope somebody can help me out. Picked up a old MBX5T to more or less restore/ refurbish it. Can the chassis from a MSRX5-T conversion kit be used in place of the MBX5T chassis? I wasn't sure if the two were interchangeable.
Thanks.....
Thanks.....
