RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 02-11-2008, 09:56 AM
  #2651
chedster
Default RE: Thunder tiger ST-1
Hmm thats good to know. I will probably just use the stock ackerman for know cuz im buying a dremel and a new steering servo. The other half will get mad if I spend to much $
Old 02-11-2008, 10:21 AM
  #2652
jombo
jombo's Avatar
i dont plan on replacing mine unless i get into a real bad crash and need to replace parts, the stock one is fine and i can deal with the slop its not that critical. now a starter box is better cash spent if you want to use a high powerd motor, that would be a better investment.
Old 02-11-2008, 11:18 AM
  #2653
spikeman
Does anyone have any opinions on the sportwerks .21 engine ?
Old 02-11-2008, 11:44 AM
  #2654
tcflyr
tcflyr's Avatar
First off I would like to say great forum! I bought a ST-1 and you guys are really helpfull. Now a couple of questions, Does anyone have the length of the steering rods when doing the steering mod from center to center at the rod ends? I saw the length of the turnbuckle posted but I might use different ends so the length would be appreciated. One more, I have a bunch of zero offset wheels I want to use and am thinking about getting some hub extensions from ofna. Are they a direct fit? shimming needed? Thanks for your help.
Old 02-11-2008, 11:47 AM
  #2655
twomanytoys
Spikeman both the sportwerks v2 engines are great. The .26 is a little monster of a motor.
Old 02-11-2008, 12:54 PM
  #2656
jombo
jombo's Avatar
i think 80 mm not too sure but here is the total mod from truggy racers
http://www.truggyracers.com/forum/in...showtopic=4424
and this is the page who uses them, i dont have them but use the 1/2 offset wheels
http://www.rcuniverse.com/forum/m_44...age_105/tm.htm
Old 02-11-2008, 03:13 PM
  #2657
KeithjV
ORIGINAL: tcflyr
I have the 15mm ofna hub extenders. I got mine from amain https://www.amainhobbies.com/advance...N30058&x=8&y=6
Here is another link http://cgi.ebay.com/ws/eBayISAPI.dll....cWAT.m240.lVI
There are two sets of holes on the extenders. You will have to drill out the hole closest to the bottom of the hub with a 3mm drill bit. The hubs come with 2.5 mm holes but the ST-1 uses 3mm pins. Then carefully sand the bottom of the extender to take off a little of the rim. After that you can just slide them on and insert the pin. Be sure not to drill the hole too much. You want the pin to be tight when its inserted. Its a much cheaper fix then getting offset wheels and new tires. With the extenders you can also use the straight tie rod ends which are stronger then the bent ones. Or you can use kyosho ends. RPM makes a set of tie rod ends but I dont know for sure if they fit the ST-1 tie rods.
Hope this helps. If you need anymore help just email me.
Old 02-11-2008, 03:55 PM
  #2658
jombo
jombo's Avatar
you can use your stock turnbuckle eyelits , just get some aluminum rod from your local hardware store and just thread the end with a die
Old 02-11-2008, 04:51 PM
  #2659
Mr.Slave
so im gunna be picking up a receiver pack, whats the best one to get? also whats a good charger to get for it? prefferably not one i have to leave over night pretty sure those are useless.
Old 02-11-2008, 04:55 PM
  #2660
ericem
ericem's Avatar
lmao i use a wall charger that charges the battery overnight, been using one for over 2 years no problems. Anything 6v 1400mah + and stick pack is perfect.
Old 02-11-2008, 05:09 PM
  #2661
madmax22
madmax22's Avatar
ok well I just finished the steering mod. it was pretty easy. we are getting 2-7 inches of snow then an ice storm! so during that time I will put it back together and im letting my throttle servo dry out so yea.
Old 02-11-2008, 05:11 PM
  #2662
xjqkz
xjqkz's Avatar
I recently bought a TTR ST-1. Here's what its doing:
1> When I start it, on idle it starts rolling
2> It turns off as soon as I take off the glow igniter
How do I fix these problems?
Old 02-11-2008, 05:16 PM
  #2663
madmax22
madmax22's Avatar
number 1. your idle it too high
number 2. you are running to rich lean it 1/8 turn. or keep it like that and let the motor warm up w/ the igniter in and take it off once it warmed up. (try not to lean it too much being that you are still in break in)
Old 02-11-2008, 05:17 PM
  #2664
Mr.Slave
make sure its broken in before you start leaning..
Old 02-11-2008, 05:28 PM
  #2665
chedster
Anyone using a pack like this? It looks like it will barely fit. I have to find my ruler to be sure.
http://www.amainhobbies.com/product_...ducts_id/18754
Old 02-11-2008, 05:42 PM
  #2666
KeithjV
ORIGINAL: chedster
Thats going to be too big to fit in the box. Im using this http://cgi.ebay.com/2-6v-1300ma-BATT...QQcmdZViewItem
They work great. There is another one on that site with a charger for a few dollars more.
Old 02-11-2008, 05:46 PM
  #2667
madmax22
madmax22's Avatar
http://www.amainhobbies.com/product_...ducts_id/14446 I use that one http://www.amainhobbies.com/product_...ducts_id/18689 but this one comes w/ the charging thing. (My LHS guy made me a custom one )
Old 02-11-2008, 05:51 PM
  #2668
chedster
Ya I need something with a higher capacity. I bought an ace high torque servo and dont think those will last to long racing but I could be wrong
  #2669
KeithjV
Those are the same size packs. I hate racers edge though. I had nothing but problems with their batteries, they wouldnt hold a charge.
Old 02-11-2008, 05:53 PM
  #2670
KeithjV
You wont see a noticeable difference between a 1300 and 1500 mah pack. Maybe a minute or two.
  #2671
ericem
ericem's Avatar
ORIGINAL: KeithjV
I had a racer edge pack as well I used in my MGT same problem. I just went to some cheap pack on ebay been working awesome. In the ST-1 IMO stick fits the best.
Old 02-11-2008, 05:56 PM
  #2672
ericem
ericem's Avatar
ORIGINAL: xjqkz
oh thats what you mean't. Ya like madmax said to rich. Maybe lean out the high speed needle first 1/8 turn. Then go to the low speed needle if it still does it.
Old 02-11-2008, 05:57 PM
  #2673
chedster
You guys know any 5cell AA packs around 2500mah that will fit in the st-1 box?
Old 02-11-2008, 06:00 PM
  #2674
KeithjV
Those packs are too big. I have a 2600mah pack and it just wouldnt fit. I needed about 1/4" more room then the box had. And I use a spektrum radio which has a small receiver and I just couldnt get it to fit.
Old 02-11-2008, 06:01 PM
  #2675
chedster
dang! Thanks
