RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 03-01-2008, 11:41 AM
  #3426
jombo
jombo's Avatar
Default RE: Thunder tiger ST-1
ORIGINAL: ska8erj
everyone says that this engine is easy to tune but my isnt. i have it rich as it can go before it laggs at start off and after about 3 minutes it is already at 250!!?!?!?!!?
whats wrong and will this change if i change to 30 %
here is a video on how to seal a engine http://www.youtube.com/watch?v=6xwDy-I0Z4I if there not resolvedthere just going to het worse going to a higher nitro content.
Old 03-01-2008, 11:56 AM
  #3427
madmax22
madmax22's Avatar
Flipping around corners? You should not be flipping a truggy on a turn any ways. Longer chassis is not always good. My track is kinda small and real technical so my st1 works very well.
lol it was just a wild stab in the dark.
Old 03-01-2008, 12:18 PM
  #3428
baboso
Banned
Ok , cool
I want to do teh steering mod but I will have to cut/grind the rods to 80mm but I dont have a grinder so can i use a manual saw that cuts through some metals?
Old 03-01-2008, 02:04 PM
  #3429
jombo
jombo's Avatar
ORIGINAL: baboso
Ok , cool
to do the steering mod you dont need to cut anything , you do need longer turnbuckles that are 80mm or longer and longer screws ,and yes you can cut them with a hacksaw as long it isint titanium .
Old 03-01-2008, 04:42 PM
  #3430
ericem
ericem's Avatar
I did the steering mod without new turnbuckles. I am pretty close to the edge but seemed like it was strong enough. I have done alot of runs. Nothing has broken yet. I will later get new rods. 80mm seems way to long though. 75mm seems a bit more suitable. Is it 4x80mm you guys use? and they work with the stock rod ends? I am going to get a spare set of rod ends and the rod just incase.
Old 03-01-2008, 05:55 PM
  #3431
ItchyBum
These are the rods i used for my steering mod and it work perfect with no modification http://www.amainhobbies.com/product_...oducts_id/6641 and these ones will work too but im not sure if they need to be cut down or anything maybe just grind 1.5mm off each end or do what i did and go caveman on them, rub it on the concrete lol http://www.amainhobbies.com/product_...oducts_id/2777
Old 03-01-2008, 07:17 PM
  #3432
madmax22
madmax22's Avatar
lol dont you have a typ of saw?
Old 03-01-2008, 07:52 PM
  #3433
soccerlaw
Ok, so Houston (i.e. Jombo, Madmax, Ericem) have a problem. The 8.4v batts in the starterbox work great. Engine starts up, revs....then we run into issues. If I give it bit more gas the wheels do not turn at all. The engine revs higher, but the car just sits there. Can I have blown the clutch already? Really would prefer not to take the clutch apart (being a noob). Any other suggestions what it could be?? Was running fine last time I used it. Are there any tests I can do to isolate the problem?
Also, it shuts off after running for about 15 seconds - is that b/c I have it too rich or do you think it is something to do with whatever problem is causing the car not to move. I think I'm about 1 more day away from sending this thing to Jombo and asking him to please work his magic!!!
Old 03-01-2008, 08:03 PM
  #3434
soccerlaw
...also, if I roll the car I can see the two gears moving so I know they're not stripped.
Another random question. What function is the short fuel line that comes out of the back right of the fuel tank (if you looking from the front of the car? It seems to come out but not go anywhere. Sorry to be annoying with all these questions.
Old 03-01-2008, 08:06 PM
  #3435
ItchyBum
lol yeah i got a hacksaw but its all old and dodgy and stuff haha and sometimes i get angry at it so i use that anger to grind it on the ground lol imagine someone grinding something on the concrete while making angry noises lol hence the name caveman style
  #3436
Mr.Slave
the fuel line is for fuel spills the idea is the fuel collects and runs down the tubing and out the bottom of the chassis
Old 03-01-2008, 08:10 PM
  #3437
ItchyBum
And also im ordering some new shock springs and iv got a choice. Do i get 4 rear springs and put a set of rear shocks on the front aswell for more travel, or do i just stick with the front and rear setup and get front and rear shocks? What do all you guys think? Iv got about 2 hours to decide and i cant get both so please lend me some advice
Old 03-01-2008, 08:18 PM
  #3438
Mr.Slave
i think my one way bearing totally crapped out on me.. definately time for a starter box
Old 03-01-2008, 08:47 PM
  #3439
madmax22
madmax22's Avatar
LMAO!!!!!!!!!!!
Take it out and spray with WD-40.
Old 03-01-2008, 08:51 PM
  #3440
Mr.Slave
nope didnt work..
its not slipping liek normal it just cant turn the motor over just kinda grinds along without turning it over (like its hard to spin not liek normal one way bearing slippage)
Old 03-01-2008, 08:57 PM
  #3441
madmax22
madmax22's Avatar
ohh lol yup its done.
Old 03-01-2008, 08:59 PM
  #3442
Mr.Slave
starter box time too bad i have to wait a while for my cheque to come and then shipping..
Old 03-01-2008, 09:10 PM
  #3443
TDS31
TDS31's Avatar
I just bought mt Thinder Tiger ST1 and haveing trouble with the one way, (rotostart) It just kinda spins took it out and cleaned it but no diffrance. the motor has a ton of compression (stock .28) so when it hit top it just stops and spins. I guess my question is, do you have to buy Thunder Tiger oneway bearing or is their a universal replacement?
Old 03-01-2008, 10:12 PM
  #3444
xjqkz
xjqkz's Avatar
has anyone tried the tt2035 pipe with LRP z28 spec3 ?
Old 03-01-2008, 10:17 PM
  #3445
xjqkz
xjqkz's Avatar
sorry about multiple posts... just another quick question...
I see there are 4 knobs on the radio and one right next to the throt trigger kind of look like a volume control!! ?
two of the white knobs are to control stearing and throttle, what are the other two for? I tried to adjust them but they don't seem to do anything? does anyone know
edit: forgot the pic
Old 03-01-2008, 10:26 PM
  #3446
Mr.Slave
look in your manual the two top one set travel limits on the throttle servo..
Old 03-01-2008, 11:30 PM
  #3447
xjqkz
xjqkz's Avatar
do you know what page in the manual?
All I see in the manual on pg 6 is: "for more details please check transmitter instruction manual."
Old 03-01-2008, 11:31 PM
  #3448
Mr.Slave
well yeah check that one..
Old 03-01-2008, 11:47 PM
  #3449
twomanytoys
The VOLUME looking one is your steering limit. This sets how much or less you want to steer.
St trim sets left, center or right on the steering
Hi controls how far you want the carb to open up when throttle is pressed all the way.
Low is how much breaking you want.
Best thing to do is have the transmitter and receiver on with air filter off (car not running) adn start moving the controls to see exactly how they work.
  #3450
grimespdx
Cant wait to get my st-1 , should be getting my tax return back soon. yup yup with have pics up as soon as i get
