RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 03-08-2008, 01:38 PM
  #3676
madmax22
madmax22's Avatar
Default RE: Thunder tiger ST-1
looks pretty good erice. now, how does it run? that is the question!
Old 03-08-2008, 01:45 PM
  #3677
The Hedgehog
The Hedgehog's Avatar
Hmm just saw jombo's pics of his batt pack, weird my protek one doesn't fit... [:@]
Old 03-08-2008, 01:48 PM
  #3678
jombo
jombo's Avatar
here ia the new mach26 on the bump box starts right up no problems ................. with 18v
http://s120.photobucket.com/albums/o...t=MOV04927.flv
Old 03-08-2008, 01:54 PM
  #3679
jombo
jombo's Avatar
ORIGINAL: AutoXMan
Got my St-1 in yesterday. My stick pack for the reciever doesn't fit though can I see some pictures of your setups?
this is the racers edge pack i have and it just fits
Old 03-08-2008, 01:58 PM
  #3680
The Hedgehog
Yeah I feel dumb, the lip I didn't see before ha ha, junky weather can break it in today.... [:@]
  #3681
ericem
ericem's Avatar
My friend with the protek pack said it fits. It's tight but fits. Right now there is like 40 cm of snow outside lol. I also need a starterbox. My friend has one.
Old 03-08-2008, 02:26 PM
  #3682
madmax22
madmax22's Avatar
its raining cats and dogs here. I wanted to go take it for a spin but my front yard has like 4 cm of water on it....... I just adjusted my breaks so now they dont rub. once my dad comes home and if he picks up engine mount screws ill take the chaos out. i g2g call him and tell him 2 get WD-40.
Old 03-08-2008, 05:23 PM
  #3683
dbuggyracer
are they in good videos of the st-1 besides you tube not alot of racing action there.
Old 03-08-2008, 05:27 PM
  #3684
madmax22
madmax22's Avatar
not really. I googled Thunder Tiger ST-1 and went under vids but they were all youtube vids. i saw one vid w/ the ST-1 racing but i cant find the vid anymore.
Old 03-08-2008, 05:42 PM
  #3685
The Hedgehog
Jombo you start your nitro inside?!?
Old 03-08-2008, 05:45 PM
  #3686
chedster
Alright guys notice my truck? It's dirty finally got to break it in! Only have like a tank thru it so gotta run it easy some more tomorrow still. Burned up like half the starter box rubber wheel trying to get it started. All I can say it wow it turns so sharp with the hitec 5955 and steering mod.
Old 03-08-2008, 05:47 PM
  #3687
dbuggyracer
i seen the same vide your talking about. i drove one a few weeks back first time i ever drove a truggy and i really liked it so i ordered one and the wing mount and the pro upper front a arms, how good does the motors run that come with them i am going to run my nova on it and sell the motor that comes with it.
Old 03-08-2008, 05:56 PM
  #3688
ericem
ericem's Avatar
Try searching up ST1 instead. Lots of good video's on youtube.
Old 03-08-2008, 10:46 PM
  #3689
madmax22
madmax22's Avatar
k ill try that ericem. hopefully the weather clears up a little more tomorrow and I can drive.
Old 03-08-2008, 10:54 PM
  #3690
jombo
jombo's Avatar
ORIGINAL: AutoXMan
yea ,its raining outside lol
Old 03-09-2008, 09:33 AM
  #3691
madmax22
madmax22's Avatar
lol i start mine downstairs and walk it to the door and then put it outside. only smells for a second or 2 i drive my chaos in the garage but i open the window and crack the garage door open.
Old 03-09-2008, 12:25 PM
  #3692
Pexeter
What adaptor do I need to get the battery holder to connect to my ST-1? I cant find it on Amain. Thanks
Old 03-09-2008, 12:36 PM
  #3693
ericem
ericem's Avatar
None ? You might have to trim off part of the connector if it has the small lip which I noticed with some connectors. You can break it off with some pliers then trim it with some scissors or a file.
Old 03-09-2008, 12:41 PM
  #3694
madmax22
madmax22's Avatar
how do you know if you have air leaks? Will it run lean when its rich as a mother? i put a tank thru the ST-1 it had a really nice smoke trail but when i would go idle it would go RRRRRRRRRRRRRRR i didnt get to do another tanks as the little black cup that holds the lower a-arm rod in broke.
Old 03-09-2008, 12:44 PM
  #3695
ericem
ericem's Avatar
Make sure the exhaust zip ties are tight. Also look at your fuel lines. Like it has that high pitched idle?? Also check your fuel lines like make sure they didn't get pinched or maybe hit the spur cb area. Another thing you can do is loosen the screw for the carb pinch bolt. Wiggle it loose a bit, then push down really hard on it make sure you linkage is still straight though and tighten the pinch bolt at the same time so that it makes a good seal. Could also be your running low speed to rich and high speed to lean.
Old 03-09-2008, 01:01 PM
  #3696
madmax22
madmax22's Avatar
ok thanks ericem
Old 03-09-2008, 01:36 PM
  #3697
ericem
ericem's Avatar
No problem! I also forgot to mention, look at the exhaust gasket as well. The one between the engine and manifold. Your idle screw might be to far in as well. ALOT of things to look at lol.
Old 03-09-2008, 03:21 PM
  #3698
madmax22
madmax22's Avatar
yup it was the LSN was to lean. run really good now! just waiting for my batt to charge.
Old 03-09-2008, 03:47 PM
  #3699
chedster
Man this axial is a PITA! It runs super rich then you lean it out and the temps sky rocket and it starts tinging at idle. There is tons of smoke and it bogs down when you throttle it. I figure its rich but then you lean out the HSN and it starts tinging.[:@]
Old 03-09-2008, 04:31 PM
  #3700
Hockey.Dad
Hockey.Dad's Avatar
Wow 148 pages, all read now though. You guys are great salesmen, I have 1 on order.
Then I can go play with my kids one is driving a Firestorm the other an Aftershock.
