RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 03-21-2008, 08:10 PM
  #4226
ericem
ericem's Avatar
Default RE: Thunder tiger ST-1
ORIGINAL: madmax22
quote:
ORIGINAL: madmax22
yea I have today and monday off. my hump pack died... and I think te diffs in my chaos are smoked.... well anyways heres a pic of the ST-1 with the new bearings and new orange fuel tubing.
Seems like all the chaos breaks is diff cups. Check them if you find some rounded then just CA glue them. Lets see the pics of the new bearings
what one do you think it is? center rear or front? I think its center b/c that one looked a little weird......
My OWB i found some JBweild so im doing that. ll tell ya how it works tomorrow. Well i fixed my cell phone! it went thru the washer machine.....
LOL that happened to my friend, except it fell in a bowl of soup I told him to just pull the battery and heat it up with a hair dryer for a long time, worked LUCKILY.
@pexter LOL it is suppost to be outside of the chassis. You want the car to see flat and close to the wheel.
Old 03-21-2008, 08:22 PM
  #4227
jay863fl
Oh, Oldschool, one other thing I have noticed, if you preheat the engine with a hair dryer it helps get it started. I guess the stock engine has a lot of pinch when new. As far as clutch shoes, I havent had any issues, BUT I am wondering how much heavier the Savage is versus the St1, maybe thats the difference? IDK, they make long life clutch shoes ( I forget the brand, dangint ) and I hear they work well.
Old 03-21-2008, 08:27 PM
  #4228
madmax22
madmax22's Avatar
i got mine to start today in the 2nd pull when it was 35F out. ericem i got pics uploading of th bearings.
Old 03-21-2008, 08:35 PM
  #4229
bronx boy
this is for the guy looking for the back plate i posted this before its thundertiger #pn0273 available from thundertiger4u.com its 8.99 it comes with everything youe need to convert to roto start on the st1 i bought it it works/fits great all you need is any brands hand held unit with the rod /wand hpi/ofna/duratrax they all fit the wand looks like a dog bone on the end it comes with the backplate/ small gear/ large gear for oneway and even the longer screws you need believe me i tried many back plates this is what you need
Old 03-21-2008, 08:36 PM
  #4230
madmax22
madmax22's Avatar
ok well here are the bearings. 2 of them are missing b/c they are in the clutchbell. they are really nice!
Old 03-21-2008, 08:39 PM
  #4231
ericem
ericem's Avatar
madmax where are they []
Thanks bronx!! Do you have the part number for a bumpstart backplate?
Old 03-21-2008, 08:46 PM
  #4232
bronx boy
no i just ordered these on a whim for my st1 and my er 1 thunder tiger both have the pro 28 look on ths tundertiger 4u website they have other versions of the 28 pro i know one is bump start only but i think you may have to change the crank not sure thoughanyway good luck
Old 03-21-2008, 09:20 PM
  #4233
madmax22
madmax22's Avatar
wow lol i 4 got the pics..... sorry buddy! here they are.
Old 03-21-2008, 09:58 PM
  #4234
grimespdx
just ordered the rotostart system. I guess we will see how it goes!
Old 03-21-2008, 10:00 PM
  #4235
dirthead
Hey check out my thread on the RC general discussions page called TTR buggies truggies and monsters oh my!
Old 03-21-2008, 10:07 PM
  #4236
Pexeter
Back to braking...
The two black post (circled in yellow), are those the actual brakes that slow the drivetrain down, is that how that works? I've been playing around with them but Im having trouble figuring out how to adjust how much braking im getting. I see people putting the percentage of braking they use in the front/back, how are they measuring that? And lastly, to adjust them, do i have to move the two deals (circled in red) either towards the spring or away from it? What do the two knuckles do that are floating in the middle of the arm (in blue)? Thanks again guys
And I think i got the starter box, I just need to wait for the battery to charge before I can see if its making good contact with the wheel.
Old 03-21-2008, 10:50 PM
  #4237
madmax22
madmax22's Avatar
the things circled in red you should tighten. EX: loosen and slide in. this should solve you problem. also the springs I replaced with little pieces of fuel tubing. the things that the red arrows are pointing to are nothing with the breaks. thats for throttle.
Old 03-21-2008, 10:59 PM
  #4238
soccerlaw
Grimes - the roto start is amazingly easy _ I just won't suggest if the engine isn't broken in yet. For those having trouble breaking in - I feel your pain - go to around post 60 and you will see all my problems!! Just make sure you pre-heat the hell out of it with a hairdryer. Also, if you start to flood it, take off the glow plug and blow out any excess fuel.
In other news, took it out for the first time with the 2035 pipe. Wow. What a difference. It absolutely flies. Can't wait to get it on the track for the first time this weekend.
Old 03-21-2008, 11:00 PM
  #4239
JChrisjohn
JChrisjohn's Avatar
Pexeter what chassi is that, and how is it diffrent from the RTR version.
Old 03-21-2008, 11:02 PM
  #4240
Pexeter
It's not mine, its from earlier in this thread. But it is from a Pro kit.
Old 03-21-2008, 11:07 PM
  #4241
JChrisjohn
JChrisjohn's Avatar
Ok so lets say I have a pro kit , (I don't ) but if I did and I broke it where would I get a new one just like it or better.
Old 03-21-2008, 11:16 PM
  #4242
grimespdx
have about 6 tanks on it right now. Turns out i just pulled the knot through the handle. I fixed it, but I ordered the roto start before I looked at it and knew I could fix it. Either way im sure I will break the pullstart again before it gets here. I actually didnt have any trouble starting it up when I first got it. Fired right out without too much strain on the pullstart. Today on the other hand it didnt want to budge, I knew it might be flooded...one too many pulls
Also I just just got my 1600 stick pack hooked up, what a difference from 4AA's. cant wait to throw a better steering servo in this baby.
Old 03-21-2008, 11:22 PM
  #4243
bronx boy
if your engine is tight just loosen the glow plug a little while you crank it with the roto start when it starts just screw it in with the igniter or your plug wrench it will start with a loose plug
Old 03-21-2008, 11:30 PM
  #4244
grimespdx
^^ good advice, I would hate to get the roto start all installed and ready to go and blow a OWB on the first press of the button.
Can summer get here soon enough? I can hear the novice 1/8 truggy and buggy class calling my name.
Old 03-22-2008, 12:06 AM
  #4245
madmax22
madmax22's Avatar
bad news.... the LHS sent me a letter and said they are closing the dirt track they are to old to maintain it....
Old 03-22-2008, 06:22 AM
  #4246
jay863fl
^^ Aw man that sucks Mad, maybe you could talk to them and let the racers take over the track maintenance. Where I am going to race the City actually owns the land, and the local RC Club maintains the track. I had to pay $65 to be a member but that allows me access to the track anytime I want year round, within reason. And each race cost like $5 for members to race, and $10 for non members. Between the $65 and the per race fees they pay for all the electricity and water. Not saying it will work for you guys, but its definately better than losing your track.
Old 03-22-2008, 07:33 AM
  #4247
oldschool77
oldschool77's Avatar
I hear you about the motor being tough to start, esp. during breakin. I have 1+tanks so far after installing it yesterday and my pointer/middle finger are numb!
I will try the loose plug idea.
Old 03-22-2008, 07:48 AM
  #4248
vnmsgt
vnmsgt's Avatar
ORIGINAL: jay863fl
Which track is that. Sounds like Avon Park. Still looking at coming out to clermont?
Old 03-22-2008, 08:21 AM
  #4249
fuoco
Pro upper arms new as of 3/21 at amain.
http://www.amainhobbies.com/product_...ducts_id/23194
Old 03-22-2008, 09:36 AM
  #4250
jay863fl
Yes its Avon Park, I looked up Clermont one mapquest, and it looks like a 3 hr drive for me, so thats iffy right now.
