RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 04-27-2008, 10:54 AM
  #4926
ericem
ericem's Avatar
Default RE: Thunder tiger ST-1
Wow itchy ill bet you lost your front brace screw in order for that to happen though. That is insane.
Old 04-27-2008, 01:52 PM
  #4927
asjak
Hi guys, the fuel tank on my ST-1 is broken again. Its the sixt time. Any suggestions?
Old 04-27-2008, 01:55 PM
  #4928
chedster
What exactly is wrong with it?
Old 04-27-2008, 02:01 PM
  #4929
asjak
It leeks in the assembling (where is glued/melted together). Is number 6 that does exactly the same.
Old 04-27-2008, 02:06 PM
  #4930
chedster
does it leak when you get it new? When you install it make sure you install the rubber orings between the mounting posts and dont tighten the screws all the way down. You want it to be able to move a little so it's not subject to all of the sudden jolts when you land etc.
Old 04-27-2008, 02:52 PM
  #4931
nitro stan
looks like your chasis is tweaked a little
that sucks man, my maxx ran away the other night, but nowhere near the damage
damage tally?
Old 04-27-2008, 02:55 PM
  #4932
asjak
I have tried 6 new tanks now. I installed them as you describe and even do after 30 minuttes run they start leaking!
Old 04-27-2008, 03:05 PM
  #4933
ericem
ericem's Avatar
Are you sure its not just your spilling fuel or something like the exhaust or fuel lines leaking fuel around the edge and making you THINK its leaking. If you don't have airleak symtoms i would leave it.
Old 04-27-2008, 03:08 PM
  #4934
asjak
Im completly sure!
Old 04-27-2008, 03:10 PM
  #4935
ericem
ericem's Avatar
ORIGINAL: asjak
Im completly sure!
wierd get a soldering iron and go around the edges that will seal it. Why would you try 6 tanks!!! I would contact ace hobbies either way. You could have even used a gas tank from the 8ight-t im sure. Probably would have had to redrill 1 hole but thats all.
Old 04-27-2008, 03:28 PM
  #4936
asjak
The dealer have replaced them each time here in Denmark. I will try with an iron and see if it will do the job. Otherwise I will replace it with an other brand...unless someone has the same experience as me and have a solution in this forum.
Old 04-27-2008, 04:34 PM
  #4937
madmax22
madmax22's Avatar
lol. itchy i think toy bent your chassis a little think I saw that pic a long wile ago..... sorry wasnt here was at a bike race. b-day is in a couple days getting some parts for the ST-1..... and a new engine
Old 04-27-2008, 05:24 PM
  #4938
kweezinarts
kweezinarts's Avatar
so got to runnin the st-1 today and i have a HUGE air leak in the carb after 7 tanks. start it and idle for a sec in hit 220 degrees and then the idle climb and climbs and climbs and on 2 occasions it even revved up pretty high. as i looked in the carb i could see the fuel bubbling around the slide. is there a way to fix this myself or do i have to ask for a new carb?
Old 04-27-2008, 05:28 PM
  #4939
chedster
This will probably fix it. Make sure the little black o-ring is still on there to. I use this to seal all my carbs
http://www.amainhobbies.com/product_...ducts_id/17237
Old 04-27-2008, 06:04 PM
  #4940
kweezinarts
i took off the boot around where slide slide pulls out on the outside of the carb but i dont see an o-ring. where should the o-ring be?
Old 04-27-2008, 06:22 PM
  #4941
ItchyBum
hey madmaxx what day is your b day?
Old 04-27-2008, 06:47 PM
  #4942
madmax22
madmax22's Avatar
the 29th this Tuesday I cant wait.
Old 04-27-2008, 07:26 PM
  #4943
ericem
ericem's Avatar
ORIGINAL: kweezinarts
check out the fuel lines and exhaust gasket and coupler.. Heck check the carb, if the pinch bolt came loose the carb came loose and it isn't sealing.
lol max your b-day is the same day gta IV comes out yay!! XD
Old 04-27-2008, 07:28 PM
  #4944
madmax22
madmax22's Avatar
lol cool. maybe i will get that from my brothers or something they will probably forget anyways....
Old 04-27-2008, 09:08 PM
  #4945
G8TR FAN
Hey guys, I believe I have a air leak issue, but not sure. I was at the track today and I could not get the TT.28 to start without it kicking my BUTT. I would have to continously tap my finger on the exhaust exit to give it fuel and once it would fire off it would idol erratically. it would rev, get hot, or just die. I removed the carb and sealled it with rvt, still no change. I sealled the backplate but it has a roto start so you cant really seal it. every since new it was hard to crank up onced it was running temp. Does this sound like air leak or not????? Any sugestions would be appreciated cause I am about to give up on this motor and just replace it if it wont run. My other nitros aren't near this much of a pain. Love the truck but I am really starting to hate the Motor!!!!!!
Old 04-27-2008, 09:14 PM
  #4946
ericem
ericem's Avatar
Check your fuel lines, tank, exhaust coupler, and exhaust gasket.
Old 04-27-2008, 09:30 PM
  #4947
chedster
You sure your not running way to lean?
Old 04-27-2008, 09:59 PM
  #4948
G8TR FAN
Dont seam to be lean, smokes seems right, I checked the settings, Bottom is 6 1/2 out and big end is almost 4. I'll check lines, tank and exhaust tommorow.
Old 04-27-2008, 10:17 PM
  #4949
chedster
Is the factory HSN setting only like 3 turns out on the TT .28? Not sure as I no longer have mine but 4 out seems rich. Check for air leaks though cuz your symptoms sound like that.
Old 04-27-2008, 11:54 PM
  #4950
outkastxjoe
Are there any after market or different brand tanks you guys would recommend? At the moment I switched to the Kyosho ST-R tank...good tank but almost half the capacity of the TTR tank. I too have had some problems with the stock ST-1 tank leaking. Any recommendations?
Oh, and I'm almost positive that the 8ight-T tank won't fit. I've been comparing it to my brother's 8ight-T and it's just way too long.
