Thunder tiger ST-1
#5103
ON, CANADA
Yes metric is correct.
http://www.amainhobbies.com/product_...oducts_id/2981
Just wanted to let you guys know that the Losi 1/2 offset hexes are a PERFECT fit and are very nice quality. 0 issues at all. I also left the 1 shim one for each axle. You use your original nuts and pins. Remember there is a set screw in the middle of the axle that holds the pin in place.
http://www.amainhobbies.com/product_...ducts_id/16340
#5106
ON, CANADA
i don't think so. You'll have to use the one that came with the st-1. did you keep it? Well anyhow, even if you didn't they are cheap. The pack of 4 is $20.99 at a-main
#5108
PA
ON, CANADA
We are talking about these ones correct?
http://www.amainhobbies.com/product_...oducts_id/4889
The one with the pullstart is pressed in. But who cares 99.9999% of the time the failure with this bearing is because of a cracked housing.
#5116
hi guys i want help! i buy four front st-1 shocks for my mad force but the upper ball end of the shock has a big hole i see in the amain the st-1 standoffs but in the st-1 manual they have something in front of the stand off and the shock something as a plastic spacer i dont see any part number!! what is it??how i will fit the shocks??i only want the stand offs or the plastic spacer??give parts!
#5117
go at yours manual guys at page 24 of the pro manual and you will see that before the suspension is a little part and before the little part the metal stand offs i want the part number of the little part!
#5119
ON, CANADA
ON, CANADA
ORIGINAL: madmax22
so the roto start doesnt come with OWB?
#5123
I agree once using the starter box you would have to be stupid to use a pullstart. A pullstart compared to a starter box is like walking compared to driving, its way easier and quicker.
This is my ST-1 PRO on my Thunder Tiger starter box http://au.youtube.com/watch?v=k0aP8vBVqBs
#5125
CA
ok whats a good oil for the diffs to run i was gettin 7,000, 3,000 and 10,000 CST stuff but duno a good "order" for it, i know rly hard for the center, a good order for it???
