RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 09-05-2008, 08:59 PM
  #6226
marshon50
Default RE: Thunder tiger ST-1
so what was the problem and what was your fix? Inquiring minds want to know....
Old 09-05-2008, 09:37 PM
  #6227
DS
DS's Avatar
well my problem was i had a big steering issue but it was a simple fix. My steering would just not turn or even put out any torque, but we found out that the servo saver became loose somehow, so we tightened it up and all i can say is[X(][X(][X(][X(] This thing steers like no other, i think i could put it anywhere. if you want more in depth info, checkout the thread (tried everything)
Old 09-06-2008, 11:34 AM
  #6228
eddyeddy
Amain finally got the extended wing mount in stock! Now just have to wait 4 weeks to arrive at home. [:@]
Old 09-06-2008, 03:56 PM
  #6229
bajaracer1501
Just FYI - [link=http://www.thundertiger4u.com/]ThunderTiger4u[/link] also has them...that's where I got mine when I saw that they were backordered at Amain
Old 09-06-2008, 06:23 PM
  #6230
calvino
calvino's Avatar
well, my starter box is on the way , can't wait to get the car goin, i found a simple way to get a little more "turn" out of the car, you know that "turnbuckle" between the servo arm and the bellcrank, if you set the car to full right, turn the reciever off, and twist the screw till the arm can't go any more, ooh man, helps a ton with the car and the turning radius [8D]
Old 09-07-2008, 06:23 PM
  #6231
revoeater76
ive got a rotostart on a stock ttr engine will it fit my pullstart spec 3?
Old 09-07-2008, 10:10 PM
  #6232
ericem
ericem's Avatar
ORIGINAL: revoeater76
nope
Old 09-08-2008, 10:04 AM
  #6233
misasi
Hey guys i need some advice. right now im running the stock motor and pipe on my ST1 but i was wondering if it would be worth it for me to upgrade my pipe. Now i know of course ill see more power but i know that soon i will be replacing the stock engine with either the Go .21 5 or 7 port engine. Now the pipe i was looking at was the TT 2035. I just dont want to buy a new pipe that wont pair up well with the new motor. Should i just stick with the stock pipe?
Old 09-08-2008, 11:23 PM
  #6234
calvino
calvino's Avatar
well, got the starter box, and got my truck goin again, OOH BOY, what fun , shure missed that "lovely" smell of nitro, did have a racing problem around the last 1/3 of the tank, what does that mean, should i get a different tank?
Old 09-08-2008, 11:28 PM
  #6235
Chedzter
The 2035 pipe is a great all around pipe. I have a Go tech 5 port that I run a 086 pipe with or used to run. Also picked up a new Ninja .21 that I run the 2035 pipe with. My advice is to stay away from the Go tech and pick up a more reliable motor. The ninja is a dream to tune while the Go tech flames out if the tune is slightly off. It does make good power though and actually can run with the ninja easily. If you go with the Go tech 5 port I would get the dynamite 086 pipe. This motor puts out alot of bottom end. The Ninja with the 2035 is just so smooth everywhere and gets almost 10 minutes of runtime.
Calvino what you mean racing problem?
Old 09-09-2008, 03:06 PM
  #6236
msg73
I'm either going with the LRP Spec3 pull start or the Jammin .28 and a starter box. Do I need buy anything else to use it in my ST-1 (i.e. mounts, backplates, clutch, flywheel, etc) ?
Old 09-09-2008, 03:47 PM
  #6237
calvino
calvino's Avatar
ok, i have to say sorry to all the guys who said starter box and i said no to, DANG its easy to start the engine, gettin used to lining it up, but other than that, WOW, starts up so easy , ran the truck some, think i ran it a bit lean [X(], wanted to race at idle, other than that, ran like a champ, didn't "drink" fuel like it USED to [8D], alltogether, fun [8D]
Old 09-09-2008, 05:54 PM
  #6238
msg73
which starter box did you get?
Old 09-09-2008, 06:39 PM
  #6239
ericem
ericem's Avatar
Well got my tools, wing mod (bought extra posts for the shock tower and mounted the wing to where the body usually attaches in the rear, you need to take out the screws and bring it up one level to the adjustable part of the mount). The tools are soo nice way easier then the damn T hex drivers. This definitely makes the body stronger. Also got a new pipe ofna 053 going to see how it drives with it.
More pics here
http://s81.photobucket.com/albums/j2...cem/Rc%20cars/
Old 09-09-2008, 06:49 PM
  #6240
calvino
calvino's Avatar
ofna compact box , fires right up, sometimes its a little "tough" but thats because im learnin , well, set up a track in our backyard (pvc pipes) and let sis do it, she's prety good , and thats with no brakes [X(], ran the engine sorta rich for her, kept the speeds down... she is'nt used to the raw power of mr nitro lol, man, this engine shure's powerfull [8D]
Old 09-10-2008, 10:19 AM
  #6241
Eganwp
Eganwp's Avatar
Anyone know which aftermarket bodies will fit on the ST-1? http://www.amainhobbies.com/product_...ducts_id/16555 one is out of stock, but I'm only assuming that it fits the ST-1.
Old 09-10-2008, 10:22 AM
  #6242
The Hedgehog
The Hedgehog's Avatar
That one fits the ST-1.
Well in October I will be sending my ST-1 to RC-Monster for them to design a motor mount for electric power on the ST-1, should go well then I have the whole winter to get the perfect brushless setup.
Old 09-10-2008, 04:22 PM
  #6243
DS
DS's Avatar
ORIGINAL: Eganwp
going with the st-1?
Old 09-10-2008, 06:33 PM
  #6244
ericem
ericem's Avatar
Ya it fits.
Old 09-10-2008, 06:56 PM
  #6245
madmax22
madmax22's Avatar
autoXman thats going to be one sweet mod!! are you going to use a servo for the breaks or the motor? what motor/esc/BEC/battery are you going to use? think the feigao 10XL motor mamba max V2 ESC a A123 battery castle creations CC BEC 10A but i want to here what you had panned
Old 09-10-2008, 09:50 PM
  #6246
ItchyBum
Im going to convert my dads ST-1 PRO to brushless with one of those novak kits. I'll use the motor mount that AutoXman uses with my own battery trays and esc mount with 2 x 11.1V lipo's or a big ass 10000 or 12000mah 22.2V and then turn the esc down for extra run time
Old 09-10-2008, 09:54 PM
  #6247
The Hedgehog
You will not fit a 12000 mah 6 cell battery in a ST-1 ROFL. Turning the esc down will overheat the esc for sure.
I am going to run a 9xl on 4 cell lipo and gear it for 35 mph, all you need for racing. I plan on using the servo brakes, but will see how much room I have to mount the lipo.
I am sending my car in after the season is over so November most likely now that I think about and he will take a month or so, then I have the rest of the winter to get it set up.
Old 09-11-2008, 09:07 PM
  #6248
madmax22
madmax22's Avatar
cool beans! yes itchy a 12000 mah battery is HUGE!!!!!!!!!!!!!!!!!!!! good choice on the 9 xl i think it will give you a very good balance between power and speed! what ESC are you going to use auto?
also who is making your mount?
Old 09-11-2008, 10:28 PM
  #6249
calvino
calvino's Avatar
X said it was i believe RC monster, man, this car shure knows how to WAIL , to bad my left rear tire rim is all dirty [&:], anyone run the wimpy TTR wing, its TINY, any good choices, i was looking at either an ofna, or J-Concepts wing for it, also, is it possible to wheelie a truggy?
Old 09-12-2008, 06:36 AM
  #6250
The Hedgehog
You really cannot wheelie a truggy because of the center diff. A nice brushless setup though can wheelie a truggy.
