RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 12-16-2008, 04:31 PM
  #6676
Eganwp
Eganwp's Avatar
Default RE: Thunder tiger ST-1
Nice presents been! Yea I got her a new Canon P & S camera, as she already has a Nikon DSLR.
I haven't messed around w/ the BCE chassis yet tho, so I'll be interested in your findings. Lemme know which dogbones are required.
I can't believe the pinch this JPX .28 has. I haven't tried running it yet, but definately can't turn it over by hand. People weren't kidding about the pinch, haha. Been, what weight shock oil are you running? I'm thinking of drilling mine out a bit, and using 60wt. or so. Right now running 50wt all around with 15mm of preload for bashing, but rear is still too soft.
Old 12-16-2008, 05:03 PM
  #6677
beenbreto
I use stock springs with jam-min harden big bore shocks with mugen 400wt in the rear and 350 in the front and when i land a jump there is little bounce it gives. what will drilling out the shocks do? have you rebuilt your diffs at all?
Old 12-17-2008, 03:10 PM
  #6678
Eganwp
Eganwp's Avatar
Drilling it out will allow more oil to pass through the 2 holes in each shock and thus allow you to run thicker oil, giving you more of a big bore feel to it. It's a common mod guys do on the ST-1 front shocks, and some do the rear as well. I think I'll try it out and report back.
Haven't rebuilt the diff yet as I need to pick up the parts on thurs night from LHS when they're open late.
TTYL!
Old 12-17-2008, 03:18 PM
  #6679
beenbreto
should i rebuild my diffs or shim them out? and how do you know when to?
Old 12-17-2008, 03:21 PM
  #6680
ericem
ericem's Avatar
You encountering issues with wear? I would just leave them as long as they are not wearing out. If they are you basically insert shims in order for the gears to mesh tight enough to a point where there is no noticeable friction. Be sure to great up the gears well with white lithium grease.
Old 12-18-2008, 01:17 AM
  #6681
r1nsho
Help!!!! I need a back plate for my st-1. I want either a spin start or roto back plate. please let me know where i can find one. thanks guys!!!!
Old 12-18-2008, 01:32 AM
  #6682
calvino
calvino's Avatar
sullivan tigerdrive, i have the S703 (inline) or the 6mm 90* will also work[8D]
Old 12-18-2008, 11:41 AM
  #6683
The Hedgehog
The Hedgehog's Avatar
Thunder Tiger has a rotostart conversion kit.
Old 12-18-2008, 11:55 AM
  #6684
r1nsho
Where can i find it? whats the part #?
Old 12-18-2008, 12:32 PM
  #6685
Eganwp
Eganwp's Avatar
FYI Been, I read on a forum that a guy said you'll need part TTRPD2367 in order to complete the BCE chassis conversion. That's all he said however. [link=http://www.amainhobbies.com/product_info.php/products_id/4937]http://www.amainhobbies.com/product_info.php/products_id/4937[/link]
Old 12-18-2008, 04:34 PM
  #6686
msg73
How will the 90* tiger drives work? I have an LRP Z28 Spec3 and at 90*, you can't get the wand in there because of the exhaust and/ or pipe. From the looks of it, you need something that comes off the corner (paralled to the pull start cord). Is there anything like that for the LRP?
Old 12-19-2008, 03:21 PM
  #6687
ericem
ericem's Avatar
Just get a spinstart backplate like the mach 427. That works perfectly fine from the back.
Old 12-19-2008, 04:36 PM
  #6688
calvino
calvino's Avatar
HELP anyone know the bearing size on the clutch BELL, i blew one of the bearings up [&:]
Old 12-19-2008, 05:20 PM
  #6689
R.M.S
Hey guys, I'm new to the forum and was sent here by a hobby shop. I have a Thunder Tiger ST-1 with the pull start and am looking for a new system. I contacted Thunder Tiger on the roto start system, but it has been discontinued. I contacted Sullivan on the tiger drive, but they do not think they have one for this application. I'm looking for someone who has completed the coversion who can tell me exactly which parts I need. It would be great if someone could help me out, Thanks!!
Old 12-19-2008, 05:55 PM
  #6690
bajaracer1501
This is the Thunder Tiger backplate that I have been using with the stock motor with my HPI rotostarter:
[link=http://www.thundertiger4u.com/roto-start-backplate-p-8632.html]Roto start backplate TTRPN0273[/link]
If I remember correctly, it bolted on with 3 screws instead of 4 but I have had no problems.
Old 12-19-2008, 06:35 PM
  #6691
calvino
calvino's Avatar
you can use the Sullivan S703 tigerdrive backplate, you will need to either shim the engine with washers or shave the "ears" down on the sides but other than that it works, the output on the back of the engine is 6MM so the closest relative to the S703 90* version can also work (inline works but sometimes its hard to feed the "wand" in through all the stuff)
Old 12-19-2008, 06:58 PM
  #6692
bajaracer1501
Here's pics of the Thunder Tiger roto backplate I'm using...easy access, straight bolt-on
ID:	1092754   Click image for larger version
ID:	1092755   Click image for larger version
Old 12-19-2008, 07:14 PM
  #6693
R.M.S
Thanks so much guys, very good info!!
Old 12-23-2008, 05:22 PM
  #6694
xtmracer41
hey guys. havnt been on here in a while. i know this sounds stupid, but its been so long since i bought a glow plug, i forget which one to get for the ttr .28
thanks
noah
Old 12-23-2008, 06:01 PM
  #6695
bajaracer1501
yo Noah, I think I was using a Mccoy #8 or mc-59
Old 12-23-2008, 06:14 PM
  #6696
bajaracer1501
Look what came in the mail today...Clockworked Picco P3 .28 with turbo head button and Jammin' cooling head to match the Thunder Tiger red. Thanks Supertib!
I'm a little torn because I just got a SavageXL and I might use it for that instead...or I just might have to order another one!
ID:	1095315   Click image for larger version
Old 12-24-2008, 10:18 AM
  #6697
beenbreto
thats a Sick motor man!!! r u goona use that for racing? can you PM me the price for that mod? thanks man
Old 12-24-2008, 02:20 PM
  #6698
beenbreto
BTW here are the pics of my BCE chassis build and Eganwp all you need is one drive shaft for the conversion and its only the rear CVD. but everything went together pretty smooth. i wanted to take it completely apart but didn't have the time for that but I did what I could.
Old 12-25-2008, 02:24 PM
  #6699
msg73
I recently got an LRP z.28 Spec3 pullstart for my ST-1 and it ripppps!!! Sooooo much more power/speed that the stock TTR engine. I also bumped up to a 14T CB and a Dynamite 086 pipe. Very pleased with the performance. I was getting bored with the power of the stock engine and the LRP gets me excited again. Easy to break in and holds a tune really well.
Old 12-25-2008, 03:08 PM
  #6700
xtmracer41
hey guys, would these hub extenders work on the st-1? if they dont, or even if you dont know, do you know of any other brands that would. i couldnt find the mugen ones on amain.
thanks
noah
http://www.amainhobbies.com/product_...oducts_id/4149
