RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 12-23-2007, 09:50 AM
  #1176
jombo
jombo's Avatar
Default RE: Thunder tiger ST-1
if yor charger uses bannana plugs yes the bottom link dosent work so i dont know what that looks like. i have the duratrax itellapeak charger so mine uses the the plastic sqare plug to servo plug
http://www.amainhobbies.com/product_...oducts_id/6414
this is where i found the right plug for mine just match up what you have with the charger you have
http://www.amainhobbies.com/index.php/cPath/1_61_128
if you need help post a picture of the charger you have
is this the batt you got if so you need something simmilar like the one i posted
Old 12-23-2007, 03:57 PM
  #1177
Matt (12 year old rc fanatic)
i just got this reciever batt for my ST-1 but im not getting the ST-1 until christmas so i wanted to know if it is a good batt and will it fit in the ST-1
http://www3.towerhobbies.com/cgi-bin...?&I=LXMEY2&P=7
Old 12-23-2007, 06:03 PM
  #1178
gtrider12345678
can you charge a battery pack at 2 amps? thats the lowest setting on my charger, but i might have to get another one if thats not ok.
Old 12-23-2007, 06:30 PM
  #1179
rican25
I am not sure about 2 amps even if you could I think as with all batteries the slower you charge them the longer they last. as far as I thought anyway.
I charge my stick packs at 2 and my reciever packs at 1
Old 12-23-2007, 06:42 PM
  #1180
ericem
ericem's Avatar
2amps is to way to high.
Yes that battery pack is fine.
Old 12-23-2007, 07:14 PM
  #1181
twomanytoys
If you havwe a 1100 mah battery you can charge it at 1 amp. If you have a 2000 mah charge it at 2 amps, 3000 mah@ 3 amps and so on.
Old 12-23-2007, 07:37 PM
  #1182
jombo
jombo's Avatar
ORIGINAL: Matt (12 year old rc fanatic)
yes it will fit ,thats the same size as the one i have
Old 12-23-2007, 09:52 PM
  #1183
twomanytoys
Well I went and bought a new engine yesterday and was breaking it in today. I had the Sportwerks v2 in it (great engine btw) but wanted to see what these axials had in them so I bought one. Nice looking motor. The owner of the hobby shop said it would beat my sportwerks. Not sure about that though but wont know till broken in and tuned. Here are some pics adn I will keep posted on its performance but first impression is good. Started very easy first few pulls and ran at idle on factory settings. High speed was extremly rich and would not rev at all. Could not get temps above 180 even with head wrapped so I had to lean it out just a tad. Idle temps finally got up just over 200. So far so good. I have 3 more tanks to really start to get on it.
ID:	832631   Click image for larger version
Old 12-23-2007, 11:16 PM
  #1184
88 STEELERS
is that the rtr motor mount? Did u have to modify it to fit
Old 12-24-2007, 12:19 AM
  #1185
ericem
ericem's Avatar
RTR and Pro motor mounts are the same height. He shouldn't have had to modify the motor mounts since the backplate on the axial .28 is flush with the block. Maybe at most he had to add a washer.
I think I found a decent wall charger for guys just starting out and needing a charger for there RX pack but don't want to spend a fortune through a-main. If you get this charger, YES it is 7.2v at 200mAh but +/-1v is safe just charge for only like 4-6 hours.
http://www.amainhobbies.com/product_...oducts_id/7939
and this adapter
SHOULD work fine just you need to charge for less time.
A good pack would be this one.
http://www.amainhobbies.com/product_...oducts_id/6259
I run this pack as well as a few of my other friends and they last VERY long at 6v through my ch3 on my rs300 receiver. So far I have owned mine for over a year and it still holds a charge and lasts just as long as when it was new.
For those of you on a tighter budget this one is fine.
http://www.amainhobbies.com/product_...oducts_id/7261
Old 12-24-2007, 01:07 AM
  #1186
madmax22
madmax22's Avatar
Its a duratrax Intel peak pulse charger.
Old 12-24-2007, 08:54 AM
  #1187
thrasher st1
thrasher st1's Avatar
how are ya fast guy, cool pics of your st1 s i have one i have just set up for sand racing but cant work out how to put the pics in here can ya help me out
Old 12-24-2007, 08:56 AM
  #1188
qaiz
qaiz's Avatar
@thrasher st1.
Welcome to RCU and the forums
Use photobucket or image shack
or alternatively use the rcu image uploader.
Old 12-24-2007, 09:50 AM
  #1189
twomanytoys
I had to put 1/8 spacers under the mounts for the speedwerks and it worked fine but the axial backplate is very small and fits perfect. The backplate on the axial is almost flush but not quite. I also use a roto start.
Old 12-24-2007, 10:26 AM
  #1190
ericem
ericem's Avatar
@madmax yes that charger will definitely work! Just pickup this adapter so you can plug the receiver pack into it.
Old 12-24-2007, 10:29 AM
  #1191
madmax22
madmax22's Avatar
ahhhh ok i see now thanks! And Merry Christmas and Happy New year!!!!!!!!!!!!!!!!!!!
Old 12-24-2007, 10:40 AM
  #1192
ericem
ericem's Avatar
Merry Christmas!!!!!!!!!
Old 12-24-2007, 12:56 PM
  #1193
jombo
jombo's Avatar
ORIGINAL: twomanytoys
on the xtm 28 i needed to raise it 3/16 of an inch so a piece of 1/8 aluminum stock and a piece of 1/16 aluminum stock and just cut to size of the engine mounts. the xtm back plate is quite a bit larger than most pull starts i noticed.
and merry christmas to all
Old 12-24-2007, 01:02 PM
  #1194
madmax22
madmax22's Avatar
I think once my engine gives out witch hopefully wont be any time soon i will try an axial. Thay look good and i hear they are just very good engines. They don't cost that much either.
Old 12-24-2007, 01:24 PM
  #1195
ericem
ericem's Avatar
Will definitely be a while these .28's tend to last long. Alot of guys get them to last 6-12 gallons. Very good quality motors and yes the axial .28 is a good mill.
Old 12-24-2007, 04:56 PM
  #1196
unluckylonestar
unluckylonestar's Avatar
how many ports does the ttr 28 have?
Old 12-24-2007, 05:00 PM
  #1197
fourwheels0
My Feedback: (7)
it's a 3 port engine.
Old 12-24-2007, 05:05 PM
  #1198
twomanytoys
Yes 3 port so it does not rev real high but it has lots of torque. They are also extremly reliable, easy to tune and possibly the longest lasting engine you will ever get. Built solid. Not the most powerful or fastest but still very good.
Old 12-25-2007, 11:16 AM
  #1199
spikeman
HOORAY!!!!!!!!!!!!!!!!! I just opened a brand new thunder tiger ST-1 and I already put $330 worth of parts on it. like proline crimefighters on 1/2 offset rims, a spectrum remote system, and a ofna truggy starter box. Those other truggies at the track wont know what hit them[sm=punching.gif]
Old 12-25-2007, 11:56 AM
  #1200
twomanytoys
It aqlready comes with 1/2 offset.
