RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Thunder tiger ST-1
Old 01-12-2008, 08:02 PM
  #1676
twomanytoys
Default RE: Thunder tiger ST-1
I just use needle nose.
Old 01-12-2008, 08:47 PM
  #1677
twomanytoys
Here are some new discount codes for the purchase of a new ST1
If Your Order Totals: You Save! Refer to Coupon#
$100.00 - $149.99 $5.00 CALPJAN85
$150.00 - $249.99 $12.50 CALPJAN812
$250 or more $25.00 CALPJAN825
Old 01-12-2008, 09:04 PM
  #1678
ericem
ericem's Avatar
ORIGINAL: madmax22
Jombo where do you get RTV??? i need some for the top of the fuel tank where the tubing goes onto the exhaust......... will probably just seal motor it just in case...
just wondering why you want to see the top where the fuel tubing goes in. If the fuel line is damaged just replace the fuel line.
Old 01-12-2008, 09:28 PM
  #1679
madmax22
madmax22's Avatar
no around the top not were the tubing is but it its kind of like a hex screw i saw bubbles coming out of it is that normal???
Old 01-12-2008, 09:30 PM
  #1680
ericem
ericem's Avatar
Well that tube coming in gives pressure to the tank. So there has to be air coming in lol.
Old 01-12-2008, 09:55 PM
  #1681
Fikse7
Hey guys, getting ready to install the TT 2035 pipe. Looks pretty basic, any helpful hints before I make the switch? Also, do I need to richen up my needle settings with the 2035?
Thanks!
Old 01-12-2008, 10:03 PM
  #1682
ericem
ericem's Avatar
From what I recall they are pretty close to the same. Just when you go run if you don't see any smoke or seems to rev lean, something like that. Then richen up which ever needle that is necessary.
Be sure when you install the exhaust that you don't pinch the seals make sure you just go over them, also helps to lubricate them with silicone lube. Usually it will slip on fine though. Also be sure to look at the alignment of how the old pipe sits. There are several different spring positions on the manifold so put it against the motor and position the exhaust and manifold then put the spring in the closest holes.
Old 01-12-2008, 10:38 PM
  #1683
jombo
jombo's Avatar
ORIGINAL: madmax22
ORIGINAL: ericem
Hey jombo you have hole shot's wheels in that photo right? I just bought some hole shots for a hard clay track. Hopefully they will perform well.
i got the rtv from walmart or any auto store (mostly walmart) and i had the same problem in this pic the exaust tube on top of the fuel tank leaks so i sealed that up i also sealed the carb by taking it out and putting a bead very carefully around it on the carb o ring it self never around the engine where the carb goes in because if some gets in the engine your done and need to take it all apart and clean her out. and also removed the starter or pull start and put some on the pull start and put it all back together and havent had a problem in over heating ,actually i had a hard time starting it because it was too rich at the stock settings and still after breakin i need to keep something over the cooling head to get it up to temp.
ericem you are gonna love the holeshot tires they stick to everything, i used them the other day and on pavement and on dry slippery dirt they performed great , its all about the tires i think and the stickier or softer the better but they wont last long because since they have sutch a high grip they will wear sooner.
Old 01-12-2008, 10:47 PM
  #1684
jombo
jombo's Avatar
i almost forgot i also green slimes the needles o rings (ae green slime from tower thats what its called ) then i sealed with rtv the idle screw and the pinch bolt on both sides of the carb (the bolt that holds the carb in) on the outside of the carb not on the threads of the carb on the inside thats a no no and thats it . you also need to make sure its all cured before you run it so you will be out 1 day with no ride .
Old 01-12-2008, 11:07 PM
  #1685
Snaut Rocket
Snaut Rocket's Avatar
ORIGINAL: jombo
ORIGINAL: ska8erj
ok
i got my st1 started after the pull start came off 3 times in a row after the first pull each timei got it runngin consistantly
but now when i rev it, it starts at idle and moves up to where i rev it to, but does not come back it keeps reving high and i had to run as fast as i could st catch it.
also it gets blazing hot after only like 3 minutes of runtime?!?!?!?!??!
whats wrong???
all i want to so is break in my baby and bring her to the track!!!![&o][&o]
you may be too lean on both needles or it has a air leak somewhere i sealed all my motors with rtv and after that i needed to lean them a bit because they were too rich.
Hey jumbo are you running a sts 28
If so How do you like it.
Break any crank shafts
Old 01-12-2008, 11:20 PM
  #1686
jombo
jombo's Avatar
i dont speek of ever owning a sts sts is on my enemy list lol. i have the xtm 28 in the st1 and what an engine for a inexpencive motor it performs really well.
Old 01-12-2008, 11:28 PM
  #1687
ericem
ericem's Avatar
Exactly what I said about my Mach 427. I picked it up used for $50. Outstanding motor and I am running a 15T bell.
Old 01-12-2008, 11:42 PM
  #1688
All4Rippin
I'll tell you what I bought that 2035 tt pipe and cut my fuel line to about 3 inches and using trinity 30 % platinum racing fuel....It kills it on the track I put a 15 tooth bel then went to a 14 tooth and its way better you can feather the trottle or punch it and the power is always there......As for the starter box deal its good they work well likeearlier posted you don't nee anything but the box and battery.....I also put a tiger drive on the 28 pro its the s680 and thats thig is the Sh***
Old 01-13-2008, 02:55 AM
  #1689
chedster
Will the axial .28 with the optional bumpstart plate fit the st-1 with no modifications? Any one have any input with this motor?
http://www3.towerhobbies.com/cgi-bin...?&I=LXPDU8&P=0
http://www3.towerhobbies.com/cgi-bin...?&I=LXPEJ6&P=Z
Old 01-13-2008, 09:28 AM
  #1690
ericem
ericem's Avatar
Yes it will. I suggest you run a 15T bell. That motor has alot of torque.
Old 01-13-2008, 09:52 AM
  #1691
madmax22
madmax22's Avatar
All4rippin can you do a test for me????? just start you mototr get it up to temps and flip it over and see how long it takes for it to stall????Thanks!
Old 01-13-2008, 10:03 AM
  #1692
twomanytoys
I have teh Axial .28 in my st1. Great engine. Tons of bottom end torque. I use a roto start backplate. The only modifications that you will have to make is to shim the engine up about 1/8 inch. The stock engine has a backplate that is even with the bottom of the engine. All other engines have backplates that sit lower than the engine and the stock mount makes it hit the chassis. Its not a big deal to shim it.
Old 01-13-2008, 10:11 AM
  #1693
ericem
ericem's Avatar
ORIGINAL: madmax22
whats wrong? Mine with only about a inch of fuel line can idle for over 30seconds.
Old 01-13-2008, 10:26 AM
  #1694
ska8erj
i have a question, what nitomethane pecent should i use after break in. im using 20% now, should i move up to 30% odonnels racing fuel or stay with 20 %???
Old 01-13-2008, 10:32 AM
  #1695
cobra26
ORIGINAL: twomanytoys
Can you tell me who's roto-start backplate you're using and a part number by any chance?
Thanks!
Old 01-13-2008, 10:37 AM
  #1696
twomanytoys
Here you go.
Old 01-13-2008, 10:43 AM
  #1697
madmax22
madmax22's Avatar
SkaterJ just keep w/ the 20% its fine. I broke all my engines in on 20% and they have laster at least 8gal's
Old 01-13-2008, 12:10 PM
  #1698
ericem
ericem's Avatar
hey madmax. I looked at that nipple on the top of the tank. I see what you mean. When I removed it there was no silicone or any teflon tape to seal it. So I just wrapped the threads with plumbers teflon tape. Now it has a very tight seal.
Old 01-13-2008, 12:24 PM
  #1699
madmax22
madmax22's Avatar
Ok thanks my dad has some in his work bench ill go do it in a lil bit!!! tyvm
Old 01-13-2008, 01:56 PM
  #1700
ericem
ericem's Avatar
No problem Make sure when you reassemble it that the white plastic piece on the side inside the tank is on the cap. Mine fell in and I later realized.
Oh btw forgot to mention something about those servo's. On the site it even says Hitec servo horn's work LOL! I didn't realize it was there. Jombo also confirmed it so that's good. I am going to get a aluminum servo arm. That should tighten up steering ALOT.
http://www.hobbypeople.net/gallery/440704.asp
