motorr!!!
GA
motorr!!!
well my wasp has a well respected number of gallons throguh it,and its time to put it to rest.
anyone have any engine suggestions?
im looking at the rossi mamba .21,picco .28 and trinity .28...i really dont want to spend over 250.
and i need a good mid-top motor
thanks
thanks
RE: motorr!!!
If your local track rules let you run a .28 there's alot f choices out there for goood to better mills in your price range. The Picco .28 can be a biyatch tune and alot of what I've heard it's not all it's cracked up to be.
One of the guys runs a new Dynamite Platinium .28 n his Savvy and it runs really well....holds a good tune and itsa screamer. The OS.30 will power the hell outta that CRT too....
Or you can hold off, put a lil extra $$$ aside and buy a very nice .21. Theres alot of info on the CRT ovr at www.TruggyRacers.com
GA
RE: motorr!!!
I really can't find myself a good engine for under 250,and I know a higher end engine will be better in the longrun.
So now im thinking about Ninja .21B01,WS7III.I really dont want a Rossi beacuse I had a horrorible experience with their engines,they may have changed a bit though.
I'm leaning torwards the WS7,just beacuse the last RB I had on my maxx was awesome.
RE: motorr!!!
the STS .21T is a monster of an engine....it will perform on par or better then the Ninja and VSpec's....as well its excelent on fuel..... the motor is gorgeous to be honest with you...
RE: motorr!!!
The STS isnt a bad mill at all bout you may not see to many of em getting 10+ gallons out of em. Check out Ebay and look at the Dadders motors...he sells them....he mods em out and you can score em for under $200....prolly not a bad deal at all...actually thought bout grabbing one for my SUT. Take a L@@K!
http://cgi.ebay.com/Dadders-Modified...QQcmdZViewItem
RE: motorr!!!
p5 powered my crt pretty well. had gotten used to running an eb 528xr and never felt that it was underpowered with the p5.
eb v-spec is also something to look into
CA
RE: motorr!!!
I'd get the new werks .28. It's a 7 port race motor that is based off there .21 and it's supposed to scream!!! I think you can get one for under $300
GA
RE: motorr!!!
The Sts's dont look bad!I need a new engine at a low price and i think this is it
Thanks for the help everyone
Anyone know a good pipe setup for it?
RE: motorr!!!
ORIGINAL: robmxrider
the best pipe for STS motors is the STS tuned pipe, without question.
RE: motorr!!!
Stay clear of the STS engine, I gave my .28 away due to it being junk, you get what you pay for and it wasnt even worth the 150 I dropped on it.
Now the ninja .21 off road engine pushes my crt very well and has great run times, about 8 min. It might be a bit over 250 but its a great power plant.
Just remember, you get what you pay for.
RE: motorr!!!
ORIGINAL: nascardad24
RE: motorr!!!
Me and my buddies all run STS engines, they are awesome...
but they are not for rookies or inexperienced people... the 28 takes a full gallon for break in, if the break in isn't done correct the motor will never work well...
99% of engine problems are 100% user error.
RE: motorr!!!
Not going to piss back and forth on sts engines, I will however let you know a rookie I am not. Ive had engines from OS-RB-Novarossi-HPI-Traxxas and others that I just dont recall and the sts was next to the worst Ive owned.
Im glad your sts is running and doing great, its just my own results that the sts was only worth the 150 buck dropped on it. Mine was modded so perhaps thats why I had the results, not from being a rookie.
GA
RE: motorr!!!
it seems like half of people have success and half of the people dont,and i don't want to be regretting wasting my 150 dollars when for 100 more could've have a nice engine.
Im just looking for an enigne that will run and run hard,without blowing plugs and overheating.
I had a sirio .23 and that was the engine that im talking about,never failed.
i wish it would fit,or could find somthing like it.
what about the .28 drake? its only 209 on amain!?!
sorry im asking alot of questions,i just want to choose the right thing.
RE: motorr!!!
Sorry for the tone of my post.. I never know who i am talking with on the other end.... So with it being the internet there are always haters and trolls...
but if your a legitimate guy, then i am sorry mate !
Anyways !
I run all different brands of engines, I also modify alot alot of engines.. I do everything from standard cookie cutter basic mods to full on mods with altered sleeve timings and lightened cranks...
Anyways the STS engines are very unique in there design, They have very bizzare sleeve and crank timings which makes them really picky on tuned pipe selection.... Actualy the only pipe I have found to actualy work correctly on these engine is the STS tuned pipe built to match these engines bizzare timings...... So if you didn't run your STS with a genuine STS tuned pipe you would never have seen what this motor can do...
For anyone interested the port timings of a STS 30 are 228 degrees on the crank, 112 on the transfer, and 170 on the exhaust..........
As well the STS engines require a minimum of 1 gallon for break in, the STS 28 will not even fully open up to 2 gallons have run thru it, and it will be a dog below 1 gallon and be a bear to tune....Anyone thinking this motor is race worthy after 5 or 6 heat cycles is going to be extremely disapointed.....I would not run the motor on a track anywhere below 1 gallon, preferably 1.5 gallons
Another interesting thing with STS mills, is that from factory STS over shims the head buttons to aid the customer in breaking in the motor, it helps keep temps up and reduces compresion.....Unfortunately unless someone removes these shims and sets the button to a proper squish the motor will run like total garbage...... It will run hot and make no bottom end whatsoever.....So if you have an STS engine and you haven't checked the head clearance there is a very good chance your motor is shimmed to run 60% LOL
for reference my STS 30 came with 1.1 MM head clearance from factory...
So if your STS was junk what were the reasons ?
And did you run the STS pipe ?
Did you allow the motor a gallon or so to loosen up and break in ?
and did you check your head button clearance ?
RE: motorr!!!
supertib...if what you say is true about the exhaust it looks like i'll be needing the sts exhaust for both of my mills then..i was plannning on running with jp-2 on the buggy and jp-1 for now on the truggy...the motors being dadders STG II .21b, and .30m both bumpstart of course
RE: motorr!!!
ORIGINAL: NewKid
RE: motorr!!!
alright well i'll get one soon haven't finished building my truck so it doesn't matter that i haven't gotten it right away anywho....have you run them on jp exhausts before? the reason being is because i have em already so i figured i'd try but i don't wanna ruin the engine....i'll prolly try those out for a while and see...and if i don't like the performance then i'll switch to the sts pipes
