Cen Matrix TR Arena
#1176
CA
To get the best performance out of your RTR Cen TR Arena, you will have to change the ring and pinion gears for the diffs over to the FRE ones. You can also upgrade the diffs to Hot Bodies ring and pinion gears or you can buy a complete set of Kyosho ST-RR diffs but that will cost some $$.
You can also run a smaller spur gear but you will have to modify the chassis and drill new holes to move the engine closer to the smaller spur gear. I did this to my first TR Arena and I used a 50T Kyosho lightened spur gear with Kyosho ST-rr diffs and a 14T or 15T clutch bell.
I also run a Go Tech 5 port turbo .21 and I could be happier with the performance I am getting form my $170.00 engine.
#1177
PLEASE HELP!!
Does anybody knows of a BCE chassis for selling?? I am looking for one for the TR Arena truggy! Even if its used, no problem.
Thank you in advance!
Kind regards
Kind regards
#1178
franciscomerc (05-28-2020)
