RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
some steering problems
Old 05-16-2007 | 08:45 AM
Default some steering problems
I am having some steering issues with my Hellfire SS. I have a Hi-Tec digital Servo with 160 oz of torque( not the greatest, but not bad either). I went to the track for the first time, and had such a hard time getting around the turns, then realized, whenever I turned right, I couldn't turn as sharply. The LHS thought servo saver too loose. Took off the whole top plate, it was tight. Then it continued. Then I realized the servo horn was stripped out, causing it not to grab. I replaced it with an alum one that came with the servo. Grabs better, but still not getting great steering...
Old 05-16-2007 | 02:01 PM
Default RE: some steering problems
Check your tow in in the front. If you have had some good crashes, you could have knocked it out. You could put in a lighter diff oil in the front. This will lock in posi less helping you turn. Other than that gas it or brake it to help turn.
Old 05-20-2007 | 07:38 PM
biggy boy's Avatar
You need Toe out in the front and less toe in at the back should help too.
Glen
Old 05-21-2007 | 10:22 AM
How many degrees of toe out on the front? It's a tight turn track
Old 05-21-2007 | 04:30 PM
My Feedback: (9)
Have you checked your EPA's on the radio and made sure both sides are maxed out properly (properly meaning far enough but not to far enough to damage the servo)? I think thats a better place to start than toe and diff fluids. But as far as front toe out, you never want anymore than 2-2 1/2 degree's. In the rear, 2 to 4 degree's of toe in is where you want to be.
