Truggy vs Buggy?
VA
RE: Truggy vs Buggy?
2d - yep, drill 2 holes in each piston making them 4 hole pistons..I used this:
http://www.amainhobbies.com/product_...oducts_id/7599
Used 1.3 pistons in front and drilled 2 1.3mm holes and then used 1.4 pistons rear and drilled 2 1.4mm holes...much better action - they feel more like a losi shock (smooth, more consistant, etc)
ORIGINAL: gtsum
VA
ORIGINAL: Jatohulk
The NT1 comes with four hole in the kite and you can change them by twisting the shock shaft and you hear the clicks. I wounder why didn't XT8 came with this shock option. Unless we are talking about the same thing.. gtsum you are talking about the little plastic thing thats in side the shock and the oil goes though the little hole when you move the shock up and down correct??
ORIGINAL: gtsum
TX
Thanks for the info gtsum, I think I will be doing some shock work in the next couple of weeks.
I rebuilt my front shock 6 different ways last weekend and I just can not get what I am looking for.
ORIGINAL: gtsum
yep, those be them. The xt8 shows optional 4 hole pistons available for an upgrade, but no place has them in stock, so I drilled my own. I got this setup tip from a local xray factory driver and it really made the truck better...that being said, the aftermarket big bores are where it is at. I raced against a kyosho str with the K car aftermarket BB shocks and it was so smooth all around the track...mine was too, but in a very high speed sweeper with undulations and bumps, he was able to go much faster through it...the BB shocks made his truck less aggressive...for 80% of the track, my drilled 4 hole piston setup was equal to his, but that one part of the track his was better (he drove mine as well and said the same thing). Bad news is the KMW BB shocks are about 150 a set...but they do look nice!
ORIGINAL: Jatohulk
ORIGINAL: gtsum
[link=http://www.kmwracing.com/cart/home.php?cat=9]KMW BB shock.[/link]
#31
VA
ORIGINAL: Jatohulk
Are these the shock you are talking about. Hit the link..
ORIGINAL: gtsum
ORIGINAL: Jatohulk
ORIGINAL: gtsum
yep, those are them...very high quality for sure...i am gonna order me a set this week I think
#32
For thats price wouldn't you expect the whole complete shocks. This is what does not come with it:
Items not included that you will need:
Stock XB8 shafts
Stock XB8 shock ends
Stock XB8 shock orings and clips
Stock XB8 shock boots
Stock plastic shock preload clips for adjustment
Losi 8ight Shock Bladders
Stock XB8 shafts
#33
VA
yeah, basically you are getting a bronze piston, machined shock bodies and the caps...you have to use all the o rings, spacers, clips, and shafts from the stock xt8. They are the shiznit though!
#34
ORIGINAL: gtsum
#35
you seem really rough with the throttle 2D, your basher roots show when your driving, for me i get much faster being smooth on and off the throttle and on and off the brakes then jabbing them.
_____________________________
when the cop pulls you up doing 234 km/h and asks if you knew how fast you were going, say "yep i had cruise control on
Hi guys, I was watching 2D's video. I thought it was some great driving. I just wanted to know what you "ttoks" meant when you said 2D was really rough on the throttle? I was at a track only a couple of times, usually try and find a local spot to practice my trucks manuverability and noticed that's how my throttle sounds from my video's. So how i'm driving is wrong? What's the wrong part, tapping the throttle the way 2D does? I drive an mbx5t and would really like to polish my driving skills to maximize it's performance. I'd like to race more often next year.
thanks for your help.
#36
VA
gxn - there is no right or wrong way to drive...everyone is different...some are very smooth on the throttle and roll into it - others are very throttle happy...others are somewhere in between..you need to find what works for you...case in point, I saw a vid of jammin jay wheeling a CRT and he was all over the throttle..blipping it all around the track...then you see other pros who are very smooth...whatever works!
#37
Watch the pros drive, Matt Gosch, Ryan Lutz (just to name a few) and they are brder line out of control. Lutz at the truggy nats was wide open around the whole track, or darn near it.
Truggy vs the savage X, Race the truggy and bash the X. I bash the revo and race the strr. Every once and awhile I'll race the revo or my 11 year old will.
Buggy vs truggy, buggy isnt as forgiving as a truggy. I had a hyper 8 when it came out and had a hell of a time, then jumped to truggy class, much more forgiving. If you can learn on a truggy and get good with it, then jump to a buggy.
I tried to jump right in with a buggy, I felt as if I was only in the way.
#38
TX
I don't think "ttoks" has a lot of experience on a dust bowl blown out R/C track like I was driving on. It's not easy at all. With no marshals I am going just fast enough to make a continuous take, the best I can, I'm no pro, that's for sure.
That track is being redone this week and will hopefully look more like is used to.
This is what the same track looks like when it is properly prepped.
