RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Dead Ninja .28
Old 10-10-2007, 06:22 PM
supertib
supertib's Avatar
Default RE: Dead Ninja .28
ORIGINAL: kthatch805
Only ran ninja plugs.. and 30 byrons.. no shim..
You have no shims under the head...or you didnt add the factory extra shims.... You may have to install some extra shims for running 30%
Old 10-10-2007, 06:31 PM
kthatch805
when i called mugen they said i didint neeed to...oh well im giving up on this thing and gettin another picco...
Old 10-10-2007, 06:43 PM
gil_millan1
come on man, $300 is too much. It doesnt even work. I'll trade it for an STS .30 or less money.
Old 10-10-2007, 06:46 PM
kthatch805
no thanks.. hopefully MOOOGEN will fix it for me Its being sent there... horrizon told me to ship it there.. i called MOOOGEN and they told me they will test it and i should get it back next week.
Old 10-10-2007, 08:32 PM
JSRacer
Hey Supertib, what's the normal running temp for a Ninja 28? I've been running rich at 275-300. I've seen temps as high as 325 and hate to see that! I've been fighting this tuning ever since I got it. I run 2 shims. Broke it in on 4. :-)
Old 10-10-2007, 08:59 PM
  #31
supertib
supertib's Avatar
ORIGINAL: TeamLosiFan
what pipe ya running it on ??? those temps are way too high...I would check calibration on the temp probe to be sure..... usualy our Ninja 28 runs hard at 240 ish.......these motors are actualy pretty easy to tune... 2 shims and 30% may be too much
Old 10-11-2007, 09:36 AM
  #32
JSRacer
I'm running an Ofna 086 pipe. How many shims would you suggest to run in it with 30%? I've fought this tune since day one and I'd consider myself decent in the tuning department?
Old 10-11-2007, 10:12 AM
  #33
supertib
supertib's Avatar
what vehicle and what gearing ??? usualy these Ninja's are ultra simple to tune.....oh 2 shims may not be enough for a new mill on 30%
Old 10-11-2007, 10:21 AM
  #34
JSRacer
I'm running it in my MBX5T. With the 14t bell.
Old 10-11-2007, 11:09 AM
  #35
MiamizFinest
MiamizFinest's Avatar
check ur clutch AND check ur LSN............for some reson ive found that the LSN on the ninja motors are very easy to have them to rich bye mistake
Old 10-11-2007, 05:25 PM
  #36
Da Smak
Banned
I'd suggest you change the pipe to a low end one. The 086 is possibly why it's getting hot.
Old 10-11-2007, 05:30 PM
  #37
Da Smak
Banned
ORIGINAL: j_blaze
i had the same thing happen a few weeks back, engine would quit after high speed passes. it was the fuell filter pulling air at high rpm's, took me an hour to see catch it, tiny bubbles after reving with lid off. it ran great on the box but as soon as i would drive it it would quit. i doubt its the clutch shoes unless the wheels are turning as you start it. clutch shoes kill the engine when you brake.
one dragging shoe can kill an engine without turning the wheels, that's a fact. but we are assured it's not. But as the engine is off to Horizon now I guess this thread is closed and all were gonna get is an ehtry saying "OMG! Those schmucks at Horizon want $150 or Iaint going to see my engine again".
Old 10-14-2007, 04:26 PM
  #38
dest
That engine comes from factory with 2 shimes installed. I'm in Germany right now and the engines are for 25 % right out of the box. For 30 % you'll need to add an extra one. I have the same engine as you and went to the states change nitro % ran fine, came back to Germany, 3 or 4 tanks w 25% and is fine again. Good luck.
Old 10-27-2007, 06:09 AM
  #39
rappidude
Hi
i have a m21b01 and have some issues with it. I replaved the bearings and now i can't tune it anymore. My question is about the shimes, it has two installed (default) and i run 20% fuel is this then correct or should i remove one?? I can't find it anywhere on the cd-rom.
Also i am thinking that my front bearing is leaking, during installation (preheat it in oven and bearing in freezer) the rubber came loose of the front bearing, i installled it back but since then it does not run anymore. What is a quick check to see if the bearing is leaking air. Blowing in the pressureline and some soapy water around the bearing?
thanks
