diff oil
i just bought the hyper st kit and i was putting the diffs together and i thought about the thickness of the diff oil, and i was wonder what would you reccomend i was thinking 5,000 in the front, 10,000 in the middle, and 7,000 in the back but im not sure any help greatly aprreaciated
I have heard that 7 up front, 10 for the center and 3 in the rear.
does the higher the number mean the thicker the oil? I swear I read that thinner oil offers more traction but that would mean the higher the number is the thinner the oil is.... right?
FL
ORIGINAL: rican25
thinner oil gives more traction because it gives the wheel with the least amount of traction the most power
which means when your out side tires are planted and getting alot of traction power is not givin to those wheels causeing them to over spin and loose the traction they have.
hope that helps
FL
ORIGINAL: qaiz
I use 6 in the front, 8 in the center and 4 in the back.
Tho I need to change it out, its crazy lol.
its to aggresive for me i'm gonna lower the rear to 1 see what happens
ON, CANADA
Lol all yull get is wheel spin.
Should be fun.
Wish there was a way to eliminate all the diffs.
My ideal power ratio would be 35% Front and 65% Rear.
Thats what im trying to achieve.
Good luck to me lol.
Should be fun.
