RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
LPR tire foams?
Old 01-02-2008, 09:09 PM
vnmsgt
vnmsgt's Avatar
Default LPR tire foams?
I wanted to know if anyone sells tire foams, molded or not that are pretty stiff that I can buy separately and not with tires. I want to stiffen up the tires on my Hyper ST pro. Part numbers too if anyone has them.
Old 01-02-2008, 10:09 PM
ericem
ericem's Avatar
Default RE: LPR tire foams?
Here you go.
http://www.amainhobbies.com/product_...oducts_id/7596
Old 01-06-2008, 07:22 AM
Tweedybird
Tweedybird's Avatar
the stock foams that come in the lpr crimefighters and holeshots aren't good enough?
Old 01-06-2008, 07:40 AM
vnmsgt
vnmsgt's Avatar
ORIGINAL: Tweedybird
They are great but I cannot find them available separately. I do not want to buy another set of tire when I do not need them.
ericem: Looks like those foams in the think you gave should work but what about the extra 1/2" width of the Hyper rims? You think the foams will be wide enough?
Old 01-06-2008, 06:20 PM
MonkeyRC
If you need a slightly wider foam, try these: http://www.amainhobbies.com/product_...ducts_id/11326
Also, here's the LPR foams: http://www.amainhobbies.com/product_...ducts_id/11326 (same foams that come with the MTR-series tires)
Old 01-06-2008, 07:18 PM
Th3pwn3r
ORIGINAL: vnmsgt
It never hurt someone to have an extra set of tires laying around though They aren't cheap at 30 a pair though.
Old 01-06-2008, 08:23 PM
Tweedybird
Tweedybird's Avatar
no your absolutely right, I have 2 sets and it gets expensive quick, but I had to buy a second set as the first set of wheels does not match the new body.
So it gave me an excuse to get a different set of track tread.
Old 01-06-2008, 08:30 PM
vnmsgt
vnmsgt's Avatar
I might just try the MT molded tire foams and if then are too big I can shave them down I guess.
