X1 CRT Project. :D (No more "IGOT" threads)
#226
Kay, so I took the entire truck apart and cleaned everything.
Looks awesome, but the diffs had a small amount of oil around them. Is this normal? Wouldn't want my diffs to be leaking. D:<
#228
MB, CANADA
wow 10 pages of u 2 goin at it....haha....
banned...most diffs tend to loose oil over time....if the diff is 100% empty with only a coating on the gears chance are it leaked out....unless its still the stock factory grease...i duno..but either way....I use BN Orings and BN seals whenever i open up a diff...its not worth it to reassemble to only have it leak a couple runns later....so get urself some extra diff seals and orings.
#229
ON, CANADA
Is he ever going to get this thing up and running
If its not his back plate, its his glow plugs.
Theres always something going on with this boy.
BTW how do you get a flywheel off an engine.?
#230
PA
lol yea 10 pages just you and banned! lol and qaiz take the clutch bell off then there should be a nut its about the size of a glowplug and your glowplug wrench will work. just unscrew it and pull on the flywheel it should pop off unless its on there like my t-maxx I had to wedge a screw driver in there LMK how it goes ( 1. clutchbell 2. clutch shoes 3. flywheel)
#231
MB, CANADA
DOOOO NOT WEDGE a flathead in there...that is soo the wrong way to remove a flywheel....that is however a Great way to puncture the front bearing seal and cause a bad air leak and Junk out the front bearing......there are a couple ways u can go about takin off a flywheel....1 is a Flywheel puller....they are pricy...but do what they do very well......2nd option is to lay the motor flat on its side....with the nut obviously off....Take a 2.5mm or a 3mm driver...my Integy Gold 3mm works great for this.......Lay the wrench on the block to touch the outter portion of the flywheel.......and whack away....Remeber to keep the head of the hex Flush as to not gouge the backside of the flywheel....Pending on how close it rides to the case that could cause issues by itself...but what ever u do...DO NOT use a flathead inbetween the block and flywheel.
#232
ON, CANADA
I gave up like 15 mins ago lol.
Ill try it tomorrow when im in a better mood.
Im ready to burn this engine lol
I just noticed.
Wont I have to change my fly wheel too.?
Ill be getting an .28 XZ, ill need a bump box for that.
And my fly wheels kinda beaten up, lotta rocks have hit it..
Thanks for the tips, will keep them in mind
I just noticed.
#233
PA
INTEGRA I only did that b/c it was my t-maxx and bought a new clutch system/ ceramic bearings for it so i didnt even think of saving it. thanks for the tip tho!
#234
You shouldn't have to buy a new flywheel unless you're buying new mounts and everything. O_o
Ordered everything yesterday...Now I'm waiting. Lol...I'm gonna take things slow when I'm setting it up this time.
#235
ON, CANADA
What do you plan to order after these parts come in lol :P
This entire thread is about rubbish and you ordering parts :P
#238
Lol...Maybe a body, and I'll be satisfied...But I'll probably get a BCE chassis and big bore shocks sometime later. :P
#240
ON, CANADA
@ banned
I have nothing more to say lol.
I just very pissed that I cant get my fly wheel off.!
Ill just buy a new one, ill be getting a new clutch + new gears too.
So rather go the whole way..
@ JB
Nope;
@ JB
Nope;
#241
Longer chassis (lengthed behind the engine)
New Gearing (buggy size spurs)
New 16mm Shocks
Low Profile body
new Weight distribution in the chassis:
engine moved toward center line and foward
radio equipment box moved foward and closer to center line
center diff bum moved foward
molded special pat. pending center diff mount
Bigger Dia. wheels & Tires
Much lighter, 1-2 oz over the roar limit of 9 lbs
Still has great foward traction despite weight moved foward and longer
wheel base.
Same easy handling CRT, just faster, and lighter!
New 16mm Shocks
Low Profile body
wheel base.
#243
ON, CANADA
I tried a mallet, a hammer, and a flat head.
And ive bruised my thumb and have 5 huge hashes on my left hand lol.
#244
Oh, wow...Did you loctite the nut on there? Lmao.
I know my collet has loctite in it from where I put some on the nut.
#245
I use a bearing puller (I have also heard them called a gear puller too) to get the flywheel off, works great. the auto parts should have them.
#246
ON, CANADA
Ill try a blow torch tomorrow.
Lol I have no idea why its so tight.
Partly the reason could be is because once my dog bone seized up and the nut rotated till the engine died on the thread.
Ill just get a new fly wheel. Im missing a few teeth on mine.
Why is a fly wheel so important.?
It dosent really do anything does it.?
#248
MB, CANADA
ORIGINAL: qaiz
do u even know what ur talkin about ?
#250
ON, CANADA
ORIGINAL: UG0TB4NN3D
It holds the clutch shoes. :P
Oh lol.
I had no idea.
Always thought that it was there so you could adjust the piston to B.D.C.
Thanks.
