Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
X1 CRT Project. :D (No more "IGOT" threads)
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 01-27-2008, 01:31 PM
  #251
UG0TB4NN3D
Default RE: X1 CRT Project. :D (No more "IGOT" threads)
You shouldn't have to be sorry for that. Lol.
Buy a Fioroni or Werks clutch. :P
Old 01-27-2008, 01:34 PM
  #252
qaiz
qaiz's Avatar
That was meant for Integra or whatever he calls himself.
I know, just wanted to humor him.
Its kind of a package deal, comes with a sliding clutch system.
Now honestely speaking, I have no idea what the differience is.
Is that a good kind or a bad kind..
  #253
INTEGRA
INTEGRA's Avatar
ORIGINAL: UG0TB4NN3D
Urg...he wont have a clue how to set up a fioroni or a Werks if he things the Flywheel has "teeth" and dosent even understand the basics behind the whole centrifugal clutch design......IM baffle'd he's kept that Nitrage together for 3 gallons without knowing the basics.
Old 01-27-2008, 01:38 PM
  #254
UG0TB4NN3D
Hey, you'd be surprised. I started RC cars not knowing a thing about RC cars, or anything like that, and now I'm not so bad.
I know the Werks clutch has a higher amount of pressure applied to the clutch bell, and so does the Fioroni clutch, but it has two shoes stacked on top of eachother, not all the way around the flywheel...And the Fioroni uses springs that curl around the shoes, which's why I like the Werks clutch better.
Old 01-27-2008, 01:40 PM
  #255
qaiz
qaiz's Avatar
You can be "baffled" all you want.
I wouldnt be here if I knew everything in the world about RC's.
And its 5 FYI.
And I know exactly what im saying, there circular edge of the flywheel is ribbed, mine is nearly dead, rocks have become lodged in there and gashed and goruged it completely.
Lets keep it simple Integra, ill say what I want, dont like it, not my problem. Deal with it.
Old 01-27-2008, 01:41 PM
  #256
UG0TB4NN3D
Fioroni:
Werks:
Old 01-27-2008, 01:45 PM
  #257
qaiz
qaiz's Avatar
Id manage with those 2 lol.
As long as I have some idea of what its supposed to look like when its done
revopqrs recommended the same thing I think, not sure tho
Fioroni Turbo Sliding Clutch Flywheel + Nut
And these shoes
Fioroni Carbon (Black) Turbo Sliding Clutch + Clutch Shim.
Ill check what clutch I get when I pick up this .28 XZ, all I know for sure its some sort of sliding clutch system.
Old 01-27-2008, 01:51 PM
  #258
UG0TB4NN3D
The last clutch I had like the Fioroni was the MIP clutch shoes, and you wrap a spring along the outside of those, and the spring came loose and was hanging out of my clutchbell, tearing up my chassis.
Old 01-28-2008, 04:17 PM
  #259
UG0TB4NN3D
Got the Ds1313 today.
It's amazing, so much faster than that crapper Z650M.
Old 01-28-2008, 05:05 PM
  #260
JB COMP
JB COMP's Avatar
well, I told you so
Old 01-28-2008, 09:30 PM
  #261
UG0TB4NN3D
Oh, and I bought the Symbio T2 body today, should be in sometime this week, also got some CVD boots.
Old 01-28-2008, 10:14 PM
  #262
UG0TB4NN3D
I had to trim the servo mount down to get the DS1313 in there, too. And the cable is kind of short. @[email protected]
Old 01-28-2008, 10:24 PM
  #263
JB COMP
JB COMP's Avatar
you had to trim it to get it to fit in your CRT?
what do you mean by
Old 01-28-2008, 10:32 PM
  #264
UG0TB4NN3D
I had to take a file to my servo mounts to get the DS1313 to fit in there, the mounts were too small. (Square that fits around the servo)
And the cable, to power the servo, is too short, I had to find a new way to route it through my chassis to get it to plug into the receiver, but it fits now, a little tight, though. Almost had it rubbing on my spur gear the first time. Lol.
Old 01-28-2008, 10:58 PM
  #265
JB COMP
JB COMP's Avatar
my airtronics 94359 was the same way, the cord just got to the RX, and the throttle servo I had so much cord I didn't know what to do with it.
Old 01-28-2008, 11:02 PM
  #266
UG0TB4NN3D
Lol...Yeah, my JR servos had huge cables, and this one had short cables.
Old 01-28-2008, 11:03 PM
  #267
ericem
ericem's Avatar
Hey guys the fironi clutch is very easy to setup. It also lasts forever with the blue shoes. All you ened to do is shim for your clutch. The werks clutch is a different story way to much adjustability. To be honest though never had a problem with running a normal 3 shoe setup. Carbon shoes and a smooth clean clutch bell are the key to a long lasting good bitting clutch. If you want a cheaper fironi clutch check into this. Yes it is integy but it is pretty much the same, I also heard you can run the blue shoes if you want.
http://www3.towerhobbies.com/cgi-bin...?&I=LXPUM0&P=7
Old 01-28-2008, 11:17 PM
  #268
UG0TB4NN3D
Oh, awesome, I'll look into that if I ever get tired of my Werks clutch. xD
Old 01-28-2008, 11:27 PM
  #269
qaiz
qaiz's Avatar
I just placed an order for 2 Werks Adjustable 4-Shoe 1/8 Off Road Clutch System (Carbon)
+ Some other crap that I know Ill end up needing
Old 01-29-2008, 05:04 AM
  #270
UG0TB4NN3D
When you get the Werks clutch, be sure to scratch the threads on the adjustable nut and put some blue thread lock on it, and allow it to dry completely (Believe me, it's worth it) :P
Old 01-29-2008, 05:27 AM
  #271
qaiz
qaiz's Avatar
Alrightt, thanks for the tip.
Should be here by next week.
Im getting that XZ on Thursday and maybe break it in on Saturday.
Old 01-29-2008, 05:29 AM
  #272
UG0TB4NN3D
O: Awesome. I want a .21 V-Spec. :P Probably gonna save a paycheck one day and buy one. Lol.
Also, put some thread lock on the thing that holds the flywheel down. Can't remember what it's called, but it's the long nut.
Old 01-29-2008, 05:31 AM
  #273
qaiz
qaiz's Avatar
I need to buy thread lock
Ill need to thread lock my engine mounts too.
And my exhaust.
And my entire truck lol.
Old 01-29-2008, 05:33 AM
  #274
UG0TB4NN3D
Lol...I don't think anything on my truck is threadlocked except my flywheel.
Old 01-29-2008, 05:36 AM
  #275
qaiz
qaiz's Avatar
I really need to thread lock my truck.!
And get new tyres, gonna go hunting for tyres tomorrow.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
