RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Muggy vs. Mutilator
Old 01-18-2008, 10:13 PM
revoskid32
revoskid32's Avatar
Default Muggy vs. Mutilator
Hi. I'm looking into truggies and i've pulled it down to these two.
http://ofna.com/mutilator.htm and yes im looking at the PRO version
http://www.losi.com/Products/Feature...rodId=LOSB0018
in your guys opioin wich do you think would do best for bashing, most bashing at the track though?
also where can i find more info on the mutilator because on the ofna site it doesn't have barly any info.
thanks
Old 01-18-2008, 10:28 PM
ericem
ericem's Avatar
Default RE: Muggy vs. Mutilator
There decent trucks a bit heavy especially the muggy. Also the muggy has its clutch issues.
Mutilator, only issue I know of is the c-hubs are weak and weak servo's.
Old 01-18-2008, 10:45 PM
spikeman
Muggy all the way!!!!!!!!!!!!!!!!! I think part of the reason the muggy has clutch issues is the big tires.
Old 01-18-2008, 11:01 PM
JB COMP
JB COMP's Avatar
I'd go with the muggy.
Old 01-18-2008, 11:07 PM
ericem
ericem's Avatar
ORIGINAL: spikeman
big HEAVY tires
Old 01-18-2008, 11:30 PM
qaiz
qaiz's Avatar
Monster Truggy
Old 01-18-2008, 11:56 PM
revoskid32
revoskid32's Avatar
I've actually decided on the 8ight ty anyway
Old 01-19-2008, 12:02 AM
qaiz
qaiz's Avatar
lol good choice.
You getting the RTR or the Race Roller.?
You mean 8ight T right, or you getting the buggy.?
Old 01-19-2008, 12:20 AM
ericem
ericem's Avatar
Perfect choice! 8ight-t is amazing!
Old 01-19-2008, 12:21 AM
revoskid32
revoskid32's Avatar
truggy, it's gonna be a heck of a time making the money for it but, yes im getting the 8ight-t rtr
Old 01-19-2008, 07:13 AM
vnmsgt
vnmsgt's Avatar
ORIGINAL: spikeman
My friend has one and when he first got it he would go through a clutch every day that we went out to run. He was ready to burn the thing to the ground he was so mad. He tried all different clutches and nothing worked. What he found out is that it has way to much chassis flex and when you compress the suspension all the clearance you put in your clutch bell and spur gear dissappears and starts to bind causing the failure. He got a piece of threaded rod about 1/4" thick and ran it from shock tower to shock tower and it bolted right up to a existing hole in it and bolted it tight. He had to bend it around the air filter but ever since he has not had a problem at all.
Old 01-19-2008, 10:28 AM
BIGAIRBEN
NOT SURE ON THE MUGGY BUT JUST GOT RID OF THE OFNA... BUT I LOVED IT, JUST FOR THE POWER ALONE. THE .32 IS ALSOME, NOT MUCH OF A RACE MECHINE THOUGH
Old 01-19-2008, 02:20 PM
vnmsgt
vnmsgt's Avatar
You can say that again! Whenever you were on the track with me running that I though you went home because it was so far behind!LOL
Old 01-19-2008, 11:58 PM
BIGAIRBEN
YOU KILL ME!
Old 01-20-2008, 12:05 AM
ericem
ericem's Avatar
LOL!!
Old 01-25-2008, 09:01 PM
trugman
muti all the way.....a bit heavy but man that .32 is a power house. best truggy i've ever bought.
Old 01-25-2008, 09:21 PM
vnmsgt
vnmsgt's Avatar
The new pro version looks alot better. I think it is wider than the original. The original mutilator with hub extensions and offset wheels was still not as wide as most truggies with no extensions and non offset wheels.
Old 01-27-2008, 04:30 AM
breese70
The mutilator is real good, since they changed the front suspension. I have one of the older versions that i did a pillar ball suspension on and it works great. Ive raced a few times with it and had great success with it . If your on a budget its a great truck for the money. if you can spend $450.00 dollars or more buy a Jammin CRT, Losi Eight-t, If not with a little set up the Mutilator is just fine.
