main diffrences between jammin crt and mutilator
WA
ON, CANADA
These are the differiences.
Longer chassis (lengthed behind the engine)
New Gearing (buggy size spurs)
New 16mm Shocks
Low Profile body (bodies from the nationals are still prototype, so
things might be changed here and there).
new Weight distribution in the chassis:
engine moved toward center line and foward
radio equipment box moved foward and closer to center line
center diff assembly moved foward
molded special pat. pending center diff mount
Bigger Dia. wheels & Tires
Not sure if Carbon Towers will be offered in the kit, however might be
option piece.
Still has great foward traction despite weight moved foward and longer
wheel base.
New 16mm Shocks
option piece.
wheel base.
OH
im a general manager for a hobbytown usa so i was able to put in a preorder for one with horizon our supplier, there about $200 more than the x1 crt. the release date is around march
