shoe problem
i have a muti with a .32 and i keep on having a prob with my clutch shoes waring out way to quick.i ve tried the stock ofna,losi alluminum and mugens but no luck.i know its a heavy truck. not sure if it becouse i went up to a 18 tooth bell from the stock 13.i use it for off road. maybe some one has had the same prob.[&o]
ON, CANADA
LOL didn't you already post a thread on this issue? or was there someone else with a multilator running the 18T bell. You need to run between 13-16T. Actually 13-15T is alot safer on the clutch. Doesn't it seem pretty slow?!!
MB, CANADA
what actualy clutch shoes have u ran ? there are specific shoes that are significantly better then others.....like Ofna Purple's and Ofna Blue's SUCK because there 6061...but if u get the Onfa Silver's which are 7075...they should last a decent amount of time.....BUT a 18t is WAY tOO much load on the clutch....im suprised it even let u bolt up a 18t..the motor slots much be half the chasssy.
ON, CANADA
I gave up trying to get the right clutch 4 gallons ago.
Its been the same since I got my truck.
The damn engine blew yesterday.
So yeah.
Need any spare parts for yours, pm me...
So yeah.
im on my 3rd. ofna has been nice enough to replace them all. the prob is that when the shoe gets too worn the motor revs up way too much.and kaboom............
what if i put the 13tooth back on and just go down on the spur teeth?think that might work. It just gets down to ,i need more top end from that .32. it has way too much touq.
MB, CANADA
ORIGINAL: trugman
white allu. and stock plast.
