radio questions spektrum vs FHSS
NY
Whats the different I know FHSS is frequency hopping so like every 5 min it changes it channel, but whats the advantage over spektrum. Is it true that a spektrum dx3 will go into safe mode during a race if someone turns on another radio on the same frequency?
Basically what makes the spektrum dx3 bad?
ON, CANADA
RE: radio questions spektrum vs FHSS
Frequency-hopping spread spectrum (FHSS) is a method of transmitting radio signals by rapidly switching a carrier among many frequency channels, using a pseudorandom sequence known to both transmitter and receiver.
A spread-spectrum transmission offers three main advantages over a fixed-frequency transmission:
Spread-spectrum signals are highly resistant to narrowband interference. The process of re-collecting a spread signal spreads out the interfering signal, causing it to recede into the background.
Spread-spectrum signals are difficult to intercept. A frequency-hop spread-spectrum signal simply sounds like an increase in the background noise to a narrowband receiver.
Spread-spectrum transmissions can share a frequency band with many types of conventional transmissions with minimal interference. The spread-spectrum signals add minimal noise to the narrow-frequency communications, and vice versa. As a result, bandwidth can be utilized more efficiently
Courtesy of Wikipedia.
ON, CANADA
Also forgot to mention.
Spektrum radios run on ISM bands, you would'nt wanna be any where close to a power plant when using one of those.
Courtesy of wikipeida again.
NY
yes i know they have a fail safe. Im just wondering if say im racing at the track with 60 other guys around with their spektrum radios on. Will I ever experience any problems?
CA
I have a mx-3 FHSS 2.4 ghz and i'd say it's one of the best radios i've ever used. Way better than my spektrum on my old savage (sold). It's changes frequecy like 2-3 times every second (i think it could be 4 or 5, not sure), and it has a great radge of features. It also has a built in failsafe. Plus, it's not too expensive =-]
WI
I have never had any issues with my dx3 going into safe mode while racing and ive raced a few races with over 80 participants alot were using spektrum radios. what happens is when you turn your radio on it locks on to an open signal and nobody else can use that signal. I believe the new dx3r uses a newer system I forget.
