RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Engine problem
Old 02-12-2008 | 10:13 AM
Farfa's Avatar
Default Engine problem
I think my engine got ****ed up [&:]
when i press full throttle the engine seems that cant run faster but its going really slow and the sound its not really good. Its not the tunning i was tunning it all the day and still hear this sound that seems like the engine cant breath. I have clear and oiled the air filter but still hear the same sound.
I would like to see some suggestions to what to do or if i need a new engine [][]
I have a mantis with 1st spec axial engine.
Old 02-12-2008 | 01:44 PM
My Feedback: (7)
Default RE: Engine problem
check your midrange needle. i'll bet it's out of wack. those engines are know for it. some have even fallen out.
Old 02-12-2008 | 01:53 PM
madmax22's Avatar
is your carb. opening all the way????
Old 02-12-2008 | 03:03 PM
How old is the engine? Broken in yet? What happens when you rev the engine then then at the same time slowly turn in the high speed needle? Does it change then? Usually if it wont rev its because its way too rich.
Old 02-13-2008 | 08:08 AM
Farfa's Avatar
ORIGINAL: fourwheels0
I will check and tell you cause i was having that problem before 2 weeks
ORIGINAL: twomanytoys
the engine its 1,5 months old and its not rich. I have broken it.
