Adjusting fuel mixture without stoping your truck
FL
Guy at our track is running this little micro servo that controls his Highspeed fuel mixture, so it can be adjusted on the fly,
anyone ever seen one of these?
RE: Adjusting fuel mixture without stoping your truck
im not realy sure but it could either be a fuel pump with out the pump
can you get a better pic because i think it clould be part of a comercial dishwasher the detergant valve with a throttle ball joint attached but i personaly dont trust something like that just spend 5 mins befour each race it seems too risky to air leeks and just dam right confusing if your engine is running weired lol
FL
I took the picture not knowing he had it on until I looked at it later and spoke with him, I uploaded on with it pointed out, sorry its not a better angle,
FL
I agree I think if your needing to adjust your fuel mixture that bad something is wrong,
It works he showed my friends and I last night but I didn't have my camera on me
FL
Its some kinda micro valve that is controlling how much fuel is being given to the carb.. kinda the same setup as a airplane motor but those have a thumb turn on them not a servo
ON, CANADA
Yes exactly all it has is a valve and the servo is attached to the valve. Not sure if that's how you want to adjust your mixture though.
PA
yea cuz if you slip and bump that trim or w/ on the controller that conroles it and goes over 1/2 urn that no good.
