Plastic spur for MBX5T?
MI
RE: Plastic spur for MBX5T?
There is no direct-fit plastic spur for the Mugen diff. I use a Kyosho center diff with the Kyosho 46T plastic spur in my 5T. You need the Kyosho center diff braces and top plate too, but they fit perfectly in the existing holes in your chassis.
I have never stripped a plastic (nylon actually) spur. They are quite durable. They do wear out some. I replace it once each race season.
MI
IF148.
It's readily available. You can get it or even a complete Kyosho diff here:
[link]http://www.rcproductdesigns.com/EigthScaleParts.htm[/link]
Should be on eBay too, if you like to go that route.
