Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
Turbo plug piston lock tool
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 05-19-2008, 04:43 PM
losi101
Default Turbo plug piston lock tool
Does anyone know where I can get one of these. I can't find on anywhere.
Old 05-19-2008, 05:30 PM
madmax22
madmax22's Avatar
Default RE: Turbo plug piston lock tool
i think on amain in tools under misc tools.
Old 05-19-2008, 07:18 PM
Spudnik
Spudnik's Avatar
piston locking tool? i would stay away from those. They will put alot of presure on your piston and con rod. What are you doing to use that tool? If it is a flywheel swap you should get a flywheel wrench. They work for2-4 shoe clutchse. I use an ofna one.
Old 05-19-2008, 08:30 PM
ericem
ericem's Avatar
Easier to just remove the carb and stick in the end of a like pier handle which is usually the same size as the opening. Or just putting your flywheel in clamps.
Old 05-19-2008, 08:56 PM
losi101
Yep it for a flywheel removal. What i'm using now is a tooth brush handle through the exhaust port. it works quite well but it's no something I want to practice. I'll give that ofna tool another look. I still can't figure out how that thing works by looking at it. I'll check a main
Old 05-20-2008, 04:45 PM
Vigilante212
Vigilante212's Avatar
It slides over the pins on the flywheel its real simple to use.
Old 05-20-2008, 08:04 PM
HighClassBasher
This is the safest way to lock the piston: http://www.amainhobbies.com/product_...oducts_id/8459
Old 05-20-2008, 10:53 PM
Jerzferno
Jerzferno's Avatar
Put a wrap of electical tape on each jaw of channel lock pliers. It wont damage the flywheel that way. Ive been doing that for years.
Old 05-21-2008, 01:01 AM
kweezinarts
kweezinarts's Avatar
ya i remove mine with channel locks too. make sure the flywheel pins nestle into a groove on the channel lock on both side and apply pressure as needed...
