RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
clutch bell
Old 06-13-2008, 10:42 AM
J24gordon
Default clutch bell
How much play should there be in a cluth bell? None at all or a little bit? Thanks
Old 06-13-2008, 10:51 AM
shankdog626
Default RE: clutch bell
A little lol
U don't want any binding happening.
Trust me, I spent a week getting the shimming
right in my new clutch bell/motor.
Old 06-13-2008, 11:37 AM
slayerphonics
slayerphonics's Avatar
ORIGINAL: J24gordon
As little play as possible.
Old 06-13-2008, 11:55 AM
phattracker
phattracker's Avatar
ORIGINAL: J24gordon
I think the paper method leaves too much play. IMO
Old 06-13-2008, 12:10 PM
slayerphonics
ORIGINAL: phattracker
ORIGINAL: J24gordon
I agree,
I just hold the spur and tip the clutch bell back and forth, until i'm happy with the clash then I roll the car on the floor and see if everything rolls smooth.
Old 06-13-2008, 03:35 PM
INTEGRA
INTEGRA's Avatar
ok he asked about the play in the clutch....meaning end bell clearance im assuming....not how tight the mesh should be.....the end play on the bell should be betweeen .3 and .4 imo the only way to accomplish this is to use the Kyosho kit and lock the bell up...then u can start to remove the appropriate #'s of shims to get the end play to around 3 or 4....the Ofna 5x8's are great for taking up space while the kyosho's are more for the fine tuning aspect.
Old 06-13-2008, 04:02 PM
shankdog626
+1
Old 06-14-2008, 01:24 AM
phattracker
Do you mean play as in holding the motor and being able to wiggle the bell in and out in reference to the crank?
Old 06-14-2008, 07:18 AM
J24gordon
yes, not the mesh i have that figured out. What bearings would be recomended as well , i'm running a crt with a jpx .28 and seem to be going though bearings alot
Old 06-14-2008, 08:55 AM
INTEGRA
INTEGRA's Avatar
ORIGINAL: J24gordon
Do u have the KH motor mount ? if not u need it......and u can run w/e bearing u can get...Protec's are nice n cheep and work great...same with Avid....cheep and effective....that Jammin is a Horny mill tho...lots of Grunt eh ?>
Old 06-14-2008, 02:26 PM
phattracker
I know this if off topic, but icant get any help in any other forums on RCU. My buddy has a hyper 7 with a hyper 21 in it. He took this motor apart and him being a noob, aparently lost the head shims. Does this motor have head shims to begin with? If so, can you tell me what thickness they could be?
Old 06-14-2008, 04:20 PM
INTEGRA
INTEGRA's Avatar
a couple .2's and maby a .1 and Yes ALL motor's in theory will have head shims....he really needs to take the motor to someone who knows what there doing to measure the clearance.
Old 06-15-2008, 10:59 PM
phattracker
Thanks INTEGRA. Sorry to interupt.
Old 06-15-2008, 11:48 PM
Oasis TR
I like to use ceramics for clutch bearings, They seem to take the heat better and dont cook the grease (you dont want to oil your clutch bearings..for obvious reasons). Proper end play is also essential for clutch bearings..Metal expands when hot, so if you set your clutch bell with no end play when it gets hot it will bind not only destroying your bearings it can also damage carbon clutches, bogs your motor..not good..I have always been told 1 to 2 mm of play.
Old 06-16-2008, 09:41 AM
INTEGRA
INTEGRA's Avatar
ORIGINAL: Oasis TR
its .3-.4mm of play.....1-2mm is way too much.
