RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Which truggy engine?
Old 06-16-2008, 07:55 AM
Tbone Revo
Default Which truggy engine?
If you could have any engine you wanted, no matter the cost, what would it be? I am looking for an engine for the strr.
Old 06-16-2008, 10:01 AM
The Winner
Default RE: Which truggy engine?
hey i want too a engine for my st-rr! but i want for 210 dollars!!!
Old 06-16-2008, 10:09 AM
rebelracer246
a good motor for under around 200 is eather the sportworks .26 or the losi 427
Old 06-16-2008, 10:13 AM
The Winner
for racing not for bashing and a 21 or 28 not 26,27,25
Old 06-16-2008, 10:17 AM
rebelracer246
i have an 8t and i race and i hold up wit the .28s and i can get pass them in the corners because i dont have as much torque as they do so i dont spit the tires as much
Old 06-16-2008, 12:39 PM
darksoul242001
ORIGINAL: Tbone Revo
If no matter what the cost then go ahead and get a GRP .21 or a Novarossi. These engines should be able to get that strr around the track no problem. Or you could also use what Ryan Lutz uses on his STRR which is the Sirio S21 CL7B STI. If you want to keep the budget under 200 bux then go ahead and get a Picco .28. This engine is insane! I'm currently using it in my Hyper ST w/ JP3 pipe and it is awesome. Here check out Ryan Lutz drive his STRR with a Sirio .21.[>:]
http://www.youtube.com/watch?v=XfJC_2E_XLs
Old 06-16-2008, 12:43 PM
rebelracer246
the grp hae had problems with flame outs
Old 06-16-2008, 01:38 PM
INTEGRA
INTEGRA's Avatar
ORIGINAL: rebelracer246
and u know this how ?
Old 06-16-2008, 01:45 PM
2DMaxLST!!
2DMaxLST!!'s Avatar
GRP engines would be at the top of my list!!
Old 06-16-2008, 01:50 PM
rebelracer246
a few pro rc races that i talk to use to run grps and they switched to os and put grp heads on them
Old 06-16-2008, 01:55 PM
Tbone Revo
I got to watch Lutz drive in person at the Psycho Nitro race in Atlanta. He is unreal. That engine is the one I am leaning towards. Its just when you go into a hobby shop they are going to push what they sale and that might not be the best enine I can get.
Old 06-16-2008, 03:46 PM
marcus falconieri
Try the new OPS .28 truggy motor at www.tkocompetitiondev.com this motor is sick fast and new to this country.
Old 06-16-2008, 05:25 PM
supertib
supertib's Avatar
I would say each of these motors has their own characteristics and attributes both good and bad...
Sirio CL7B is a motor with a very smooth powerband and a very strong midrange.... It has a softer bottom end which makes it very easy to drive, it carries very good trigger feel in the midrange and pulls hard to a respectable top end.....This motor is suited more to someone who doesn't like alot of bottom end power, as this motor will feel a little laggy at low RPM's, so it will suit a smoother rolling drivng style, this is not a point and shoot motor ..... In kyosho STRR which carries very good corner speed this motor will do very well, as its midrange pull is among the best i've felt from a .21.... Tuning is very easy on this motor as well, it starts instantly and idles very well...
Picco 28/JPX 28........ This is not a smooth motor, it hits very hard in the low end and pulls hard across the whole RPM range... This motor carries tremendous trigger hit across the whole RPM range...This motor is well suited to heavy truggies or someone who has a point and shoot driving style.... These motors are not the best on fuel, with an average of 7 minutes per tank...These motors also need a little carb sealing to work 100%.... They can be picky to tune if there is any airleaks or inconsistencies with the fuel supply.... But overall the JPX 28 is a fine motor...
Picco 21/JPX 21 This motor is very similar in feel to the JPX 28, just not quite as violent.... For a .21 these motors can hit extremely hard in the low end , they have instant trigger feel and spool up very rapidly..They also scream like a **** on top end.. The JPX .21 will outrun the JPX 28 if given a little room, but these buggers will usually outrun pretty much everything on top end so thats to be expected..... These are my personal favorite engine, as they feel more like a .28 then a .21 as they hit extremely hard when they come onto power... for my track conditions and driving style these motors rock..... If you are a point and shoot driver and want instant hard hitting power these are the best motors I have found...... They are definitely not the smoothest easiest to drive .21's, but they idle awesome and get great mileage..... For anyone who runs a .28 and is scared a .21 wont have enough snap should look into these Picco's before any other .21...... For someone who drives in low traction and likes a smooth motor these Picco's are likely not the best choice.........
Old 06-16-2008, 05:42 PM
crazy4wdracer
His engine is insane. I was at the Ohio State Series in Medina, OH and I was watching him race it after the race I was standing by his pit man when he took his truggy off the track and the engine was running at 250 degrees.
Old 06-16-2008, 06:14 PM
Oasis TR
I run a Novarossi Plus 21-7BT in my ST-RR and on the tracks that I race on it has more than enough HP..brutally fast, great bottom end..very usable power..cant ask for much more..10 minutes on a tank also.
Old 06-17-2008, 10:33 PM
PENGUINBLASTER!!!
PENGUINBLASTER!!!'s Avatar
I run the jpx 28 and like it so far, haven't even made it through break-in though.
Price fluctuates on amain like crazy, bought mine when they were 189.99 http://www.amainhobbies.com/product_...ducts_id/11201
Old 06-18-2008, 07:38 AM
The Winner
ORIGINAL: supertib
cl7b sti or the stock??
Old 06-18-2008, 07:48 AM
INTEGRA
INTEGRA's Avatar
the STI. and modded on top of that aswell.
