RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
I Got Issues.
Old 06-17-2008, 02:38 PM
phattracker
phattracker's Avatar
Default I Got Issues.
My clutch bell keeps "locking up" on my motor after a tank, or sometime during that tank. I've tried several different shim setups, but none are working. I have a 14t Ho Bao on a OFNA Force .28. The bearings are good. I'd throw new ones in there if they were bad, and when i take it apart to troubleshoot/clean everything seems fine. Upon putting it back together with at first 2 shims in front of bell, worked fine, ran a tank, locked up. Then 1 shim up front, spins nicely, ran a tank, locked up. No shim, spins freely, ran a tank, locked up. What can I do to fix this? Thanks.
Old 06-17-2008, 02:46 PM
slayerphonics
slayerphonics's Avatar
Default RE: I Got Issues.
ORIGINAL: phattracker
Your clutch shoes could be mushrooming, and won't reset to the resting postion.
Old 06-17-2008, 02:58 PM
phattracker
thsnks for the quick reply. They are mushroomed a bit. didnt even think it was enough to affect anything. I will dremel them down a bit and let you know. Thanks again. peace.
Old 06-17-2008, 03:23 PM
RcRacer37E
Make sure the bell isnt to tight against the spur. Should have just a bit of lash between the two.
Old 06-17-2008, 04:21 PM
hkenvy91
ORIGINAL: slayerphonics
thats what i was thinkin
Old 06-17-2008, 04:47 PM
shankdog626
Check your Flywheel nut isn't coming loose and throwing things forward too.
Old 06-18-2008, 12:31 AM
Oasis TR
My guess is your clutch bell is to tight, you need some play, the clutch shoes mushrooming would not do what your explaining..you are running the washers under the clutch shoes..right.. It sounds like as soon as the temp comes up your "locking" up..check your end play on your clutch bell..remember when your clutch bell heats up it will expand some..if your tight when it's cold (still spins but with no play) as soon as you get heat into the bell it will lock up.
Old 06-18-2008, 01:40 AM
phattracker
Well, all metals aren't created equal. How does the material rank that Ho Bao or OFNA uses for thier bells?
Old 06-18-2008, 05:09 AM
stussman
I sometimes have it lock up but mainly the opposite, the screw loosens and clutch bell loosens. Ive tried threadlock, plumbers tape, different screws. After 5 minutes run time its way loose.
Old 06-18-2008, 09:45 AM
Oasis TR
a friend of mine is having the same problem..I dont even lock tight mine..it never comes out..
Old 06-18-2008, 12:58 PM
McFly505
Loc-tite on the screw is a bad idea, IMO.
TRACKER>>>> You need .3-.5mm clearance for expansion, or you will continue to have these problems.
I try to give it about twice the clearance you would set your mesh at, if you understand what I mean.
Scott
