trouble with my 8 t
PA
trouble with my 8 t
I am having trouble with the fuel to the motor. I'm gunna try my best to explain. When I go to start the truck I am getting a lot of air in the line. I hold my finger over the exhaust until the fuel line is fuel from the tank to the carb. As soon as i take my finger off the exhaust the fuel getts sucked back into the tank( amost all). So then i tryed pulling the exhaust line the goes to the top of the fuel tank, to try to prime it and when i blow in that the fuel line fills and then it flows back into the tank when im done!!! WT* I checked the lines for cracks or slits and there is none. I pulled the floating brass thing in the tank thinking maybe there was something wrong with that. Didnt work. Now when i blow there the exhaust line to prime I can hear a bubbling noise coming from the carb threw the air filter.
Please if you have an idea please let me know. Thanks
MB, CANADA
RE: trouble with my 8 t
you are experiencing heat soak on the carb...the carb is Sooo hot that its Vaporizing the fuel before it has a chance to get into the motor.....basically...your running too lean...richen it up a bit...let it cool....and try again.
