Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
questions about 8-t throttle servo/linkage
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 07-13-2008, 09:54 PM
g-townmach
Default questions about 8-t throttle servo/linkage
Are the problems w/ the 8-t servo's burning up because of the actual servo or beacuse of the throttle linkage. My question is, is it only the 8-t RTR's that are having their servos burn up??..because its an improper end point setting on the servo from the factory? Or is it the actaul linkage or something else causing the problems so it will effect the roller version? Reason being is that i'm thinking about doing the race roller and using either a hitec or hobbico servo for the throttle and of course ACE 1015 for steering.. but i might second guess it if everyone is having these problems b/c i don't like to buy new servos unless it was my own fault for breaking them.
Old 07-13-2008, 10:21 PM
rebelracer246
Default RE: questions about 8-t throttle servo/linkage
what it is the endpoints arnt really set right from the factory and the servo tray flexes if you dont have them set right i have only blowen one so far knoc on wood
Old 07-14-2008, 07:23 AM
SycoCell
Yeah ditto. But mine blew for some odd other reason. I always set all my EPA's before running it. But it could have been caused by the flexing of the tray as well.
Old 07-14-2008, 07:51 AM
rebelracer246
ya that will do it
Old 07-14-2008, 01:49 PM
FatBoyObese
I must admit that I set my epa's before every run too....just can't afford not to as the servos I run are not cheap lol.
There are those around that say you don't need the 'o' rings under the battery box on the 8ight t but I still use them as I haven't got the balls not to just in case I trash another servo
Old 07-14-2008, 02:09 PM
slayerphonics
slayerphonics's Avatar
Most people are blowing the cheap weak stock servo, if your blowing high dollar servos your doing something wrong, i've run a hi-tec 685mg for about 8 months with problems, but i did blow the stock servo,
Old 07-14-2008, 02:14 PM
rebelracer246
i only blew a cheap servo but i havent blew a good servo yet
Old 07-14-2008, 03:51 PM
SycoCell
I don't use those o-rings under the reciever box. I would have, but i was in the a rush to change out throttle servos right before my main began, so i lost the rings.
Old 07-14-2008, 04:00 PM
K_B
K_B's Avatar
I'm currently running the radio tray with no o-rings and a tray stiffener and I blew out an Airtronics 358 recently. Turned out that I forgot the spacers to get the servo off the chassis. I'm pretty amazed it lasted 4 months with the beatings and vibrations it was subjected to I just blew a Hitec 5997 this weekend. Not sure if it's the dodgy servo lead or the setup. Linkages weren't absolutely perfect but not way outta wack either. I'm hoping it's the servo lead... gonna run the o-rings from now on and see what happens.
Also, instead of o-rings, a fellow racer is using two layers of double sided servo tape instead. It still provides the necessary cushion, but you don't have to fool with threading o-rings...
Old 07-14-2008, 04:20 PM
rebelracer246
im not running the orings and i am running the stiffiner and i blew a crappy servo so im not that upset
Old 07-14-2008, 04:25 PM
windowlicker
windowlicker's Avatar
what actually causes the servos to give out, just out of interest? Is it because the EPA has been set too far and the linkage is straining to move further under full throttle or braking?
Old 07-14-2008, 05:17 PM
rebelracer246
that and its because the servo its self is twisting and they dont like to do that alot and if they hit the chassis that will crack the case and short the motor out
Old 07-14-2008, 06:45 PM
K_B
K_B's Avatar
ORIGINAL: windowlicker
It can be one or more of many things; EPAs, binding linkages from chassis/tray flex, improper clearance between chassis and servo, or just poor quality servos.
Old 07-14-2008, 06:57 PM
SycoCell
I'm surprised the radio tray isn't aluminum. My muggy has an aluminum stock stray. Plus that muggy one is 100x faster to remove since the 4 screws are right on the top
Old 07-14-2008, 07:20 PM
rebelracer246
there is only 4 screws on the 8t and its off i can get it out quick
Old 07-14-2008, 08:46 PM
g-townmach
thanks for the replies
Old 07-14-2008, 08:53 PM
rebelracer246
no problem
Old 07-14-2008, 08:57 PM
g-townmach
so is it safe to say that if i use a quality servo in the race roller w/ the o rings under tha tray and the endpoints set right (which i know how to do and am pretty anal about) i'll be good??
Old 07-14-2008, 09:00 PM
rebelracer246
you should be unless you get the one weird servo that blows as soon as you put it in witch i have had lol
Old 07-14-2008, 09:10 PM
SycoCell
Yeah taking them off is easy. But putting it back on is a tad more annoying because it's on the under-side. Yeah i know, it's not that big of a deal, but it's just one of those things that bugs me since there isn't anything else i can complain about on the truggy!
Old 07-14-2008, 09:13 PM
rebelracer246
lol ya i know i have only blown a servo and lost a drive pin and blown shocks
Old 08-29-2008, 06:26 PM
FatBoyObese
ORIGINAL: rebelracer246
Have to agree with you there....changed my stock rtr servo for an ACE DS1015 as I wanted a little more power and speed on the steering and it lasted all of 1 minute...and yes I had set it up properly
Turned out that although it is marketed as a metal geared servo there is a plastic gear lurking in there and it gave up....servo saver was backed right off as well so it should have been fine..got a HiTec HSR5995TG in there now and it's peachey
Old 08-29-2008, 08:57 PM
INTEGRA
INTEGRA's Avatar
ORIGINAL: FatBoyObese
the 1015's are supposed to have that plastic gear....its no fluke.
Old 10-02-2008, 10:26 AM
travis4380
Here is a great link on how to set your throttle servo up. You may have to register to see it, but it is worth it.
[link=http://hdrcvideos.com/forums/viewtopic.php?f=63&t=5308]Throttle set-up[/link]
Old 11-06-2008, 12:03 PM
FatBoyObese
ORIGINAL: INTEGRA
Must admit I was gutted when I found out....specially when it was marketed as an all metal gear servo[:@]
Are there any servos that you know of that are all metal or do they all have a plastic gear lurking in them.
Looking for a high power servo to replace the ace
