* . _ - Offical Jammin X2 Thread - _ . *
#76
CO
RE: X2 Build Up W/ Pics, 56K Warning, Complete Build Info W/ Detailed Pics
The body is supposed to be stronger(from what i've read) I use ace ds1015's for both throttle and steering and haven't had any issue's with them. I also use a dx3r radio with a 3100 receiver
#77
ORIGINAL: J24gordon
Cheers
#78
CO
I use a marathon 1600, it last's almost all day when i forget to charge it,it dies in the main about 20 min in lol(3- 7min qaul's 30 min main)
#79
CO
Got my x2 today!!!! I'll proly build the front assembly tonight, can't wait to get it running now
#80
ON, CANADA
Congrats.!
We want pics.!
Take your time building it.! And DO NOT forget to shim the diffs correctely.!
Also, dont forget to screw the rear skid plate on when your attaching the rear end of the car on.!
I found the squeak.! It was the insane clutch shims im using. Got around 7 - 10mm in just shims LOL. Nothing to worry about.!
We want pics.!
#81
some wip pics :
Things are beefy & nice except for the diffs. I like the Thunder Tiger ones better. Changed all the internal gears to the hardened type. The HB or sacker ones fit.
Regards,
Joe Ling
Regards,
Joe Ling
#82
ON, CANADA
Nice pics.
Noticed you used the washers on the steering plate, I gave up with them a long time ago. IMO They dont add anything.
Just used silver nuts with the screws straight on.
Just a question. Why'd you change the diff gears.? The Jammin ones work fine. The diffs in my Buggy havent been looked at for probably 7 - 8 gallons, and its still going strong..
#83
Hi gaiz,
My experience stems from the X1 buggy. When I took the diff apart for a fluid change, I noticed that among other things, the slurry contain silvery particles in suspension. I can only assume that the particles are from the spider gears. So, I changed the gears to hardened ones. On a separate incident, I managed to strip the spider gears on the center diff on my sacker buggy that has been converted to BL electric. Again, the gears look very similar to the silvery ones that the X2 has. So, as a precaution, I just changed everything to hardened gears. Not a very expensive exercise anyway.
Regards,
Joe Ling
ORIGINAL: qaiz
Nice pics.
Nice pics.
Regards,
Joe Ling
#84
ON, CANADA
ORIGINAL: J24gordon
#85
ORIGINAL: qaiz
J, where are my pics.!
ORIGINAL: J24gordon
Gaiz I must offer you props... if there was to be a rookie of the year award for RC I would give it to you..you have gone from being a complete Greenhorn to becoming somewhat of an expert almost overnight..I remember you arguing about the Nitrage.. Now your pimping only the best of the best !!!!! Anyways just thought I would offer you props !!!
#86
CO
Sorry qaiz got busy with work, just got done with the front and rear assemblies so i'll get pics up as soon as possable
#88
Hmm where i can buy stering rods becouse i damaged my (kyosho wheels its not good idea...) [:@]
#92
CO
yep they came with the kit they are pretty cool, they are ribbed and so are the inside of the tires
#93
CO
well just finished build, I did put some diferent parts on it (stronger ar things i liked more) Enjoy!!!!! When I get my x1 cleaned up i'll take some compare-o shots
#94
ON, CANADA
Damn.
Mines no where near as clean as that.!
Just got back from the track, will post pics shortly.
J24, I know ive not sent you my setup yet, ive improved it, will make the changes and send it across.
Lord this thing handles well.
Didnt even take my buggy outta the car, was having so much fun with this .
#95
CO
yea it's too clean lol, wife won't let go to the track so i'll have to wait till next weekend, which is a cash race I set it up with Taylor James's setup which I got from jammin's site. I also added some pics to my last post, the X2 looks alot like the X1 but a heck of alot lighter, and cleaner lol. Thanks for all your info here qaiz I used it a few times with my build.
#98
its a trash traning body from my on-road,i want throw this away, but i cut this in some places and tadam! its fit great
#100
ON, CANADA
Nice X2's guys.
J24, dump that OS 28 in there, and we'd have identical X2's .
I didnt know they posted Tylor James's setup. Gotta go check that out.!
Just some random pics of it.
I love these lil' fuel line clamps im using.!
Lost a body clip from the fuel tank
Body and wings' taken a beating
Engines still going strong.!
