OFFICIAL HOT BODIES LIGHTNING STADIUM PRO/PRO-R THREAD
NY
One thing that i was wondering about is if there is any way to improve the steering. thanks
NV
RE: OFFICIAL HOT BODIES LIGHTNING STADIUM PRO/PRO-R THREAD
get the kyosho 777 22 deg. caster front carriers, tighten the servo saver a little (comes too loose out of the box), and ditch the stock tires and get some prolines(preferably LPR) should fix your problem as long as u have a decent servo seeing as the LSP ia a fairly heavy truggy.
NY
i have panther tires, an assoociated s2008 MG steering servo. i will try the kyosho parts. could you give me a link
NV
OH
I used all HB parts to change over to the 22 hubs and buggy upper front arms.
Upper A-arm conversion
Part#
8011-1 22 degree C-hubs
8134 Screw and ball for steering
8012 Upper susp pins
8116 Suspension holder
8158 Plastic A-arms
KYOIS053 Kyosho ball ends
8003 Lightning bumper
Part#
8158 Plastic A-arms
ORIGINAL: Coaltrain
Part#
8158 Plastic A-arms
Part#
8158 Plastic A-arms
OH
Sorry it took me so long to get back on this, I've been out of town for last week or so. 8116 is the part that I used(black plastic), if you bought your LSP new you should already have it, it was included in the box. And yes 8005-1 is the front upper arm I used, I did have to grind about 5mm off of the tierod to get -2 deg caster up front. KYOIS053, are offset and allow for more steering throw without rubbing on the back side of the wheels.
Thanks for getting back to me. The reason I was asking about the ball ends was because yours didn't seem to be offset in your picture. They're the ones at the end of the upper arms correct?
OH
ORIGINAL: Jckrue29
