.28 vs. .21
VT
.28 vs. .21
So I have the LRP spec3 in my CEN MATRIX TRUGGY. Fast. VERY fast. Run times are not that good though. Should I think about a .21 for this thing? Would a .21 have enough power? Any suggestions?! THANKS!
VT
RE: .28 vs. .21
Well my budget is more about reality than dollars. I am not winning world championships but I do know that you need to spend to get a good motor and I am not afraid to do that. I would say $200.00 - $250.00 would e what I expect to pay unless the deal of a lifetime comes along. I was looking at the GO .21 5 port. I have the Go .21 3 port sport in my buggy and its been a nice engine. I was also looking at a GO .25 race engine. Also looks nice. I run a Matrix Truggy, its a little heavier. I do want something with some power if I go to a .21 engine. Any other ideas???
THANKS!
THANKS!
MI
RE: .28 vs. .21
In my ST-1 i use the GO .25 race engine. Its fast and has plenty of power. I also have the GO .21, your fuel economy will be better with the .21 without a lose of power.
RE: .28 vs. .21
ORIGINAL: joydude630
.21 will have more power and good run time. What's your budget?
But you can also make a huge different if you use the proper tuned pipe, what pipe R ya running?
CA
RE: .28 vs. .21
My budget is not "huge" either..but I have bought both cheap and expensive motors..my choice is the upper end motors..and the biggest reason on why is not so much performance (as in a lot more) but in durability..most of the "cheaper" motors I have bought are pretty much done (as in time for a rebuild) at about 3 gallons..I'm on my 9th gallon on my Novarossi and it's still just as fast as it was when it was broken in..I know guys that have gotten 14+ gallons out of RB motors..On the .21's..They are my choice for power..I feel that they have more than enough power for "most" tracks, on some tracks a strong .28 actually has to much power and just over powers the track..On some tracks you need the power of a .28 to clear the jumps..but .21's are not slow..well the good ones are not..I just think that a lot of the .21 versus a .28 is driver preference and track specific..if you race on a slick track more HP is not going to make your truggy easier to drive..
FL
RE: .28 vs. .21
A .28 will have more power and less run time then a .21
Racers use .21's for the run time,
If you want a .21 in the 200 dollar range look at the "GO" line up of engines. Sirio, Picco would be some other good choices in the 200 range. My friends and I have been running the new "GO" 3 port r-spec, its impressive for a 3 port at 170 bucks, and it does sound ALOT like a v-spec, but we are running that engine in a buggy though, I have heard of some guys killing it with that motor in a truggy though.
MB, CANADA
RE: .28 vs. .21
IF u can wheel a .28...and venturi it to do 8-10 min...imo there's no advantage on the .21's part.....Sure 1-2 min's in a 45-hour long main might matter....but most club racer's push 20-30 min mains.
CA
RE: .28 vs. .21
I am running a Go Tech 5 port turbo in my Cen Matrix Tr Arena truggy and it run great. Even with the heavier Tr Arena, the 5 port has more than enough torque to push it around.
CA
RE: .28 vs. .21
ORIGINAL: INTEGRA
RE: .28 vs. .21
Man, I've tried a few engines in the truggy but why does this Mach 427 keep making it's way back? I'm a firm believer in the Mach. Now if someone could put a wicked mod on the Mach 427 we'd have something that everyone could run!
MB, CANADA
RE: .28 vs. .21
ORIGINAL: JSRacer
ive ran a modded mach...nice power...but the run time's weren't there if i remember right.
RE: .28 vs. .21
With the stock Mach and Muggy pipe I get a full ten minutes.. It's not brutally powerful(I get passed by VSPECS down the straight, but that also has to do with setup.. My settings are quite rich.. - but then I was temping 212 at the end of a 20 minute semi..), but perfect for a beginner racer like me.. I'm spinning my wheels around most of the track as it is..
Here on a German forum btw, I read something about a new Sirio - the green 21 everybody's been raving about, which has beem modified to be a .24..... Anybody heard about that?
And what's the verdict on the Axe Rosssi 25??? At least in theory these 25 engines seem a nice solution to the 21 v. 25 debates....
RE: .28 vs. .21
A Mach is a solid motor ..... I remeber the run times were very good on the modded Mach....I know today I could make a Mach much better then I ever did in the past....
FL
RE: .28 vs. .21
ORIGINAL: HerrSavage
I think I have the artical somewhere.
RE: .28 vs. .21
ORIGINAL: sparko
I run a .21 V-spec in a jammin crt and have more than enough power and we all know how heavy those crt's are
Sirio cl7b sti is wicked, 300 bucks and has more than enough power to run the 400 plus engines down. Match the pipe for the track. Short track look for a low to mid range pipe and larger track a mid to high end pipe. Its nice to have a few pipes to work with.
