OMG THE TRUGGY SCARED THE HELL OUT OF ME
I thought i knew what i was doing when i tryed to start my truggy i got it started but then it was accelerating uncintrolable on the starter box please help idk y it did that it scared the hell out of me
RE: OMG THE TRUGGY SCARED THE HELL OUT OF ME
Linkage set correctly? Take the filter off and make sure there's just a little gap there of about 1mm?? Turn radio and truck on and give gas and brake and see how the gap looks.
CA
Same exact thing happend to one of my buddy's motors yesterday. If the idle gap is fine, I'd pull the motor and seal it...possible air leak somewhere. (most likely carb neck or backplate...in my friends case it was the carb neck) Also check for any tears in your fuel line. This is the sealer that I've been recommended... [link=http://www.amainhobbies.com/advanced_search_result.php?keywords=lucky+7]Lucky 7 engine sealant[/link]it applies very cleanly but you can also go to your auto parts store and use copper rtv.
FL
ORIGINAL: INTEGRA
RTV Copper iS NOT fuel proof...and will only mask the air leak temporarily.
MB, CANADA
ORIGINAL: slayerphonics
Itegera i've been telling people that. I even did an experiment to show people and they still didn't believe me.. i'm like whatever use your automovtive gasket maker
ORIGINAL: INTEGRA
Let the Meathead think what they want....when there PULLING OUT there hair from a tuning issues....and we all know its an air leak...they can have fun trying to figure it out and ruining there day and possible the motor itself.
ORIGINAL: INTEGRA
MB, CANADA
ORIGINAL: stussman
I have cracked thermo insullation on my os28 carb. I seal it with copper rtv, lasts for a short amount of hard core run time and needs sealing again, every time. So i agree with the above.
ORIGINAL: INTEGRA
buy some proper sealant and you can forget about re-sealing every couple weeks or so.
