stock engine mounts??losi
DE
I just got my new losi race roller. It came with the stock engine mounts. I am planning on using a pull start engine to start off with. Does antone now if these mounts will work??? Will there be enough clearance??? Do I need to buy anything additional now other than the motor????
RE: stock engine mounts??losi
I believe that the race roller motor mounts won't fit a spin start or pull start backplate. The 8IGHT-T race roller engine mount PN is LOSA9154. The mounts are lower profile to allow the flywheel to be lowered and work with starter boxes. I believe that you can however install motor mounts from the 8IGHT-T RTR, and those will work with a pullstart, LOSB5032.
Here are the race roller mounts-
Here are the RTR mount-
