8ight-t chassis change
Im swapping out my rtr chassis with a race roller chassis on my 8ight-t. Still running the 427 for now with the drill start. Where its recessed out for the engine on the roller chassis there is not enough room for the spin start plate to sit down tight to the chassis.So the engine mounts sit a couple ml higher in the back. Should I shim up the front of the motor mounts with a couple washers,or dremel out the chassis to except the spin start plate? Hopefully this makes sense. Has anyone ever ran into this?Thanks for any suggestions or coments.
PA
well what you SHOULD do is ditch that spin start and get a bump box. sport werks sells a backplate that fits the 427. But if you are stuck on that spin start you can buy special engine mount washers made by OS engines to raise the engine a few mm. They are available at tower and probably some more places.
ORIGINAL: JAMMINKRAZY
FL
ORIGINAL: steve307b
If I got the back plate from sport werks would I have to get new new engine mounts to lower down the engine so the bump box would work? Or would the bump box work? I thought I read something about this before.
Ok guys I ordered the sportwerks back plate for the 427. Can anyone recommend an engine mount set that will lower the engine down to reach the bump box. Are they all the same? Didnt really want to get the quick change , they seemed a little pricey. And whats wrong with the losi bump box, everyones telling me not to get it and get the ofna box. I really dont no the difference. I would think losi puts out a good box for their products. And lastly will this be all I need to convert to bump box. Thank for all the help.
CA
I liked the King Headz extended motor mount when I had my 8T. You WANT a quick change motor mount especially for the 8ight so that you can check your clutch bearings periodically and not have to set your gear mesh everytime you remove/install your engine.
TX
The Losi 8 bump box is junk. I bought a OFNA one for my buggy. The same day my friend bought one for his 8 Truggy. Had problems from the very first time he tried it. The OFNA was perfect. No problems at all. Last week, 2 weeks after he bought it both motors burned up in it. The cars dont fit that good on them... Get the ofna.,....
ORIGINAL: TRIPC
CA
10244 Ofna Truggy starter box and be done with it. It gets the unanimous vote everytime and is the box I see the majority use at the track.
Thanks alot. I did read the reviews on Amain for that box. Seems like the way to go. I've only been into rc for three months now, didnt think I would convert my rtr to bump box this quick ,but here we go.
CA
Yo Steve,
I was in your same position so I know what you're going through..haha My girl bought me an 8T rtr as my first "real" rc car in July and I converted everything to race roller/upgraded parts in a matter of a month or so. Remember that ebay is the place for your spares! I bought most of my spares from [link=http://stores.ebay.com/NITRONUTZZ_LOSI-8IGHT-T-TRUGGY_W0QQcolZ4QQdirZQ2d1QQfsubZ17579690QQftidZ2Q QtZkm]Nitronutzz[/link] laters
FL
ORIGINAL: bajaracer1501
Just buy the losi lowered mounts for 20 bucks, then when you take your motor take it off the mounts, don't take the mounts off with the motor attached or you will have to set your gear mesh again.
But Baja is right, the bearings are something you will need to check. The 8ight lives on a diet of clutch bearings ;p
Yo Steve,
Yo Steve,
I did just get the 8t roller engine mounts instead of the quick change for now.
Thanks again for all the help guys
CA
if you need a quick change engine mount let me know, i have one in the truck and a spare i will sell you cheap. i have the 10244 Ofna starter box. it to 10mins to modded it to work i can post or send pics of my work if you need them but this box has twin 775 motors rather than the 550 losi's
the mods are very clean and professional and very simple.
FL
I am about to make this same move. So, if I wanted to keep my Mach 427 and the roto-start, but use them with the race roller chassis, what would my options be?
I have the rtr mounts and the race roller mounts and it appears that both of those will be to short to accomodate the roto-start.
Has anyone actually run the rtr mach 427 with the roto-start on the race roller chassis?
If you use your 427 with the drill start on the race roller chassis you will have to use the rtr engine mounts to allow room for the drill start back plate. The race roller chassis is a little different as it is not recessed out as much as the rtr chassis is where the drill start sits at the back of the motor,because it is meant for bump start engines. So when you mount your 427 with the rtr mounts the motor will sit a little high in the back. I mounted my friends 427 on a new chassis like you want to do and just shimmed up the front of the engine under the mounts. No big deal and it works fine.
The only motor mount that will work wthout having to shim the motor up a bunch is the Losi RTR mounts. Most, if not all, aftermarket mounts are designed to keep the engine as low as possible so they can only be used with a starterbox.
