Need Help With a Problem with my Mammoth St Tranny
CA
I just put on a new clutch bell and installing new metal spur gears
The question I have is whats the best way to allign the motor and tranny up.. so I do not mess up the gears or clutch bell.. any tricks so I know I have the proper spacing between them
CA
RE: Need Help With a Problem with my Mammoth St Tranny
It's probably in your tuning of the engine or if you changed the gear ratio it could need some adjustment [:-]
