Go Back  RCU Forums > RC Cars, Buggies, Trucks, Tanks and more > RC Truggy
Reload this Page >
!!Post Your Brushless Truggy Pics!!
RC Truggy Trucks and buggies together make a truggy. Discuss all things truggy right here.
Old 03-19-2010, 10:08 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
Default RE: !!Post Your Brushless Truggy Pics!!
My Jammin .5 CRT Pro
Hobbywing 8.5t BL system with a 60A ESC sucker runs cool to the touch on a 14t pinion and can royally rip down the street and is perfectly controllable
The battery being so high doesn't really impact its COG too badly either. It will only rollover turning when going over 80% throttle on grass
wonder *** is wrong with the uploader and why its not resizing uploaded pics to thumbnail size anymore
EDIT: reuploaded the pictures so the thumbnails work properly and you don't have to scroll to see. Glad they fixed the uploader
ID:	1401278   Click image for larger version
ID:	1401279   Click image for larger version
ID:	1401280   Click image for larger version
Old 03-20-2010, 08:05 AM
pubmaster861
venom how top heavy/rolly is your trug? seems to me that batt up high would raise the COG
Old 03-20-2010, 01:14 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
in all truth I had the battery mounted vertically on the left prior to moving it up
it flipped way easier making right turns with the battery on the left vertically than it does now. But then again mounting the battery vertically pushed its COG up already so now its higher but centered.
Only time out of the 15 mins I ran it so far (destroyed the futaba 4004 I was using as a steering servo ordered a Hightec 645mg to replace it) it flipped was when I was going full throttle and did a hard turn in grass if I go somewhere between 50-80% throttle it don't flip. Once the servo comes, and I get my other truck finished(waiting for its BL system to come) I'll be taking it to the track on a open run day to see how it preforms there.
you can see on this pic from before I moved the battery on the left what I meant about it being pretty high up and weighing down one side already. in honestly from how it was before during the 1st test the COG probably went up about an inch only and is dead center now.
Old 03-20-2010, 03:53 PM
snoking16
snoking16's Avatar
I am thinking about converting my ST-1 to brushless. I have never run Electric before. What is EVERYTHING i would need to convert it? and how much will i be dropping on the conversion? thanks
Old 03-20-2010, 04:05 PM
SyCo_VeNoM
SyCo_VeNoM's Avatar
ORIGINAL: snoking16
well
over $350 prolly closer to $400-450 for a good setup
You will need a decent BL setup which is around $200 minimum $120 for Lipos (that wil get you 2 HK turnigy 5200mah 2s 30C lipos and a charger) and a conversion kit which can cost from $30 upto $90 (dunno on your model) Or you might have to fashion your own out of aluminum if there is none. Pinions are also kind of costly most are $10 a pop.
my 1/12th scale jammin would have cost me over around $180 to convert (not counting batteries) if I didn't already have a BL system laying around(it still cost me around $80 in parts). 1/8th scales are a lot more to do
Old 03-20-2010, 04:10 PM
  #31
snoking16
snoking16's Avatar
what would you suggest for motor and ESC?
Old 03-20-2010, 06:10 PM
  #32
SyCo_VeNoM
SyCo_VeNoM's Avatar
you might want to look at the 2nd post in this thread just noticed that one is a ST-1, and has a list of parts
also http://rc-monster.com has alot of conversion kits
Old 03-24-2010, 12:01 AM
  #33
MCSRacing
MCSRacing's Avatar
here's a couple of my truggy
ID:	1403785   Click image for larger version
ID:	1403786   Click image for larger version
Old 04-01-2010, 05:00 PM
  #34
DS
DS's Avatar
how long does a battery pack last?
Old 04-01-2010, 10:48 PM
  #35
j-boy
RC8Te
This was what I did to the poor batt tray to get my TrueRC's to fit...
This is almost done with batts in place...
And heres the finished product... I'm callin it The "Lightning" rod, lol
Old 04-29-2010, 01:49 AM
  #36
mail4ajo
I have ordered the RCproductsdesigns ST-1 conversion kit and Mamba Monster 2200kv combo. Need to decide on the battery and gearing soon. ST-1 gearing suggestions are welcome.
Old 04-29-2010, 09:20 PM
  #37
TRXRUSTLER
My Feedback: (7)
TRXRUSTLER's Avatar
My RC8Te with a Novak HV Pro 7.5 on 4s. This system was not made for a truggy but I took out the stock 16t pinion and put in a 13t and I turned up the power output and it rips. It still gets hot if I bash with it but on the track its fine.
ID:	1428165   Click image for larger version
Old 04-30-2010, 01:42 PM
  #38
worstluck
good luck with those novak systems guys. ive had that esc set my truggy on fire.
Old 04-30-2010, 10:25 PM
  #39
TRXRUSTLER
My Feedback: (7)
TRXRUSTLER's Avatar
The esc I have is the newer ones that don't have as much problems as the older ones with the purple heatsink, mine has the black heatsink. Also I have the 7.5 system so it doesn't get as hot as the other ones. I also have it gear pretty low to reduce heat.
Chris
Old 05-01-2010, 07:16 AM
  #40
worstluck
the black one is what i had. just saying keep and eye on it.
Old 06-02-2010, 11:58 AM
  #41
TRXRUSTLER
My Feedback: (7)
TRXRUSTLER's Avatar
Yep I am having heat problems, I wonder if this power system would be good in a 1/8 buggy?
Thanks, Chris
Old 06-16-2010, 11:46 PM
  #42
Paron34
Get a Xerun 150a combo Run 4's with a Caster Truggy and good gearing and youll hit 50 mph and turn on a dime while running at room temp.
Old 06-17-2010, 12:04 AM
  #43
HRCules77
HRCules77's Avatar
Here's some pics of my Robitronic Mantis with an outrunner.
For the build, you can check out the KillerVolt thread.
Link to a short video:
www.rcuvideos.com/video/KillerVolt
ID:	1454236   Click image for larger version
ID:	1454237   Click image for larger version
ID:	1454238   Click image for larger version
